Aluminum honeycomb floor panel Mastercraft Prostar 190
Hi - don't know if anybody can help me. I have a 1996 Prostar 190 and am having the interior replaced. Where the engine cover mounts to the floor panel has been damaged and I am wondering if anybody knows who makes the panel itself? Is it possibly made by Bellcomb? Thanks!
The problem was the washers used were not large enough. I put a wood stripe across that section of the floor to spread the load. Drilled new holes and used longer bolts. Worked like a charm. HDPE would work as well if you have issues with the whole wood in a boat thing (understandable).
Previous: 1993 Prostar 205 Red 1998 Closed Bow Ski Boat, Ford 351, 310 hp, Acme 4 blade, Perfect Pass SG. FAQ Tyler Ski Club To me, this forum is about love of inboard boats. It is about the sharing of information and, on a good day, some humor. It is not about post count, brand of boat, or any other superfluous labels that lend themselves to a false sense of superiority. Please, respect one another, try to pass on accurate information, and keep your eye on the ball. |
Thanks for your response - a new section was added to support the hinges, but it is still badly damaged. Looking for a new panel.
Can you just flip it around?
ITCHIN' TO SKI, LET'S GO!! 1985 MasterCraft Skier, Stars and Stripes 351W with PowerSlot and Perfect Pass Click here if you need prayer, or wish to pray for those who do.
That's exactly what I did to mine...it has held up fine for over 5 years that way.
I just replaced the entire panel with 3/4" pressure treated plywood. After putting a few coats of fiberglass and a few coats of resin on the plywood, it is just as smooth as the original and fits perfectly and is very solid. Cost was about $55 dollars total as I had to buy a full sheet of plywood.
I can't comment on how long its going to last but I would guess that it will last a while as it is completed glassed in. |
Sorry to hijack your thread, but I have a similar situation in my BF200. The aluminum floor panel makes a slight aluminum foil sound when stepped on, and has a little give that I'm not too happy about. I took the panel out, and it seems that the bottom aluminum piece has separated from the honeycomb area. Was it ever determined where to buy a new sheet? I looked into replacing it with wood, but the section on my boat is 1" thick. That would make a ton of additional weight vs. the aluminum. Any thoughts?
Thanks! |
Well, you could probably go with 3/4" and put 1/4" strips on each edges...
#10
Panel replacement
Hi, I replaced my aluminum panel with a 1" plastic panel. Its heavier but will not rot. I was able to remove the carpeting and replace it on the new panel. the panel was about $65
