Old 02-01-2013, 04:20 PM
dvsone79's Avatar
dvsone79 dvsone79 is offline
Boat: '99 ProStar 205V
Originally Posted by mccobmd View Post
I have divider pics at home I'll post later tonight.
Awesome. I'd like to see those as well.
Old 02-01-2013, 05:21 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
I usually run the 1100lb bow triangle full up front when surfing and the rear sac on the surf side full. The box weight keeps the corner of the platform from dragging and making the wave wash over.
2003 X2
Old 02-02-2013, 12:13 PM
mccobmd's Avatar
mccobmd mccobmd is offline
Boat: Mastercraft X1 2006 310HP
Here is th 1/2 inch poly board that I cut to match the divider. Put holes through it and countersunk the screws with sunken washers on the sac side and locking wing nuts on the other side all stainless steel. The second picture is with hard tank out and 750 sac empty. As on other poster said with a one way valve it will suck the sac dry. The last is with it full. There is the same clearance to the manifold as if it was empty.
Old 02-02-2013, 06:06 PM
kalamalka kalamalka is offline
Boat: mastercraft x1 2006
Thanks for the pics. Do you have a pic of the surf wave too?
Old 02-02-2013, 10:59 PM
mccobmd's Avatar
The first is me, I'm 6'4" so the wave is 2 1/2 to 3 feet, I ride from 2 to 8ft behind the boat. In the second picture you can see the length
Old 02-07-2013, 09:09 PM
Okay, I got the hard tanks out and the bags put in place. Do I just leave them like that, or do they need to be strapped down with something? Will them move around and pull the hoses out when full?
Old 02-07-2013, 09:35 PM
dvsone79's Avatar
When they're full, they'll balloon out and there won't be any room left for them to move.
Old 02-07-2013, 09:40 PM
dvsone79's Avatar
Do you think poly-board is strong enough that you could just replace the dividers with poly-board? I had imagined reinforcement using steel brackets and beams, but if poly-board is strong enough, I'd consider using it.
Old 02-09-2013, 09:28 PM
mccobmd's Avatar
I have only the polyboard and it maintains the normal distance with the 750 full. I was going to add a divider but but it holds fine.
Old 02-10-2013, 11:13 PM
mccobmd's Avatar
Here is the engine compartment with the original divider in place, polyboard has been attached to it, 750lb sac full. No extra support other than the polyboard.
