#121
As this is a hardened shaft, the heating and cooling from welding may play a part in changing the hardness. I am not a metallurgist, or even play one on TV, but there are some folks on here that are qualified to speak to that.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WEEKEND WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#122
There are machinists qualified for the job, lots of machined, hardened shafts on heavy equipment, that are more cost effective to weld and grind. They just have to use the right process.
I know several machinists build up crank journals when appropriate replacement bearings are NLA - you can bet that is hardened as well. |
#123
If the groove is from rubbing on the log and the groove doesn't contact any seal, I would leave it alone. I would think that the welding would be a bigger problem than the groove.
If you are concerned about it snapping off and the prop getting into the rudder, you might install a shaft anode above the strut. That would keep it from sliding back in the event of a shaft failure. http://www.go2marine.com/product/990...aft-zincs.html
'96 ProStar 205 SD LT-1 |
#124
Personally, I'd buy a new shaft and install. I would not rely on 5200, JB Weld, or any other supplemental product to secure a mechanical application. Your call. I know the objective is to be as frugal and self-serving as possible but in this case, I'd resort to a new part. If the groove is not in a sealed area and does not evidently present a vibration, run what you have the way it is. On the other hand, if it were to work for your needs, all the better. Any warp, wobble, or off-balance harmonic motion will eventually wear on the cutlass bearing. I too would not think Vaseline would present a problem with the minimal application. Here's a link to the MSDS. http://whatsinproducts.com/files/bra...sh%20Scent.pdf Table Guy pretty well summed it up. +1 $0.02 .
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 03-17-2013 at 12:52 PM. |
#125
when I worked at an industrial machine shop it was very common to weld a shaft and turn in back down with the appropriate procedures. if the shaft rides on a seal I wouldn't hesitate to have it welded up
1981 MasterCraft 19' Skier 351W PowerSlot Deluxe Long gone is the Trans AM
#126
As for the shaft, there is very minimal play at the prop end when in place. However, I know there will be some vibration in my worn shaft in comparison to one with no groove at the bushing. If I can get it welded for cheap and not make things worse it would be worth it, otherwise I found a few places online that will make a new one for about $250. A dual taper would be nice, but I dont plan on frequent shaft replacements, so the old single taper will do. |
#128
Back to original topic- transmission is in and bolted up. Shaft is lined up. Now its just hooking everything back up and seeing if it runs. Too late to run it tonight, will be a few days.
#129
Good to see things coming together on this. Anxious to hear how it works out.
#130
That $250 quote you got on the shaft doesnt include the coupler, does it? The $300-350 for the dual taper does. I have not found a new price on a single taper shaft + coupler that was lower than the dual taper system when using the appropriate discounts. Really, its a no brainer.
Again, with grooving on the shaft, I would not run it as-is. I would not invest a dime in trying to fix it. Just replace it, or risk ruining a day on the water, along with losing your prop, if it breaks. Good job on getting the strut lined up (I assume you lined it up to the point where the shaft spun freely and was not sagging under its own weight?). Sometimes it takes a bit of coercion to get it there.
PCM 351w, 350hp |
