#111
I think if you start a new thread on this, it will get more traction.
'96 ProStar 205 SD LT-1 |
#112
2) Even when i slowly increase the throttle to 3600rpm it still has the issue 3) I have owned the boat for 6 months and put 20 hours on it. The issing just started happening. There is no rev limiter as such, at full throttle the engine will do approx. 4800rpm. It doesn't cut out like a car rev limiter it just won't go any faster. 4) Yes, i have the correct prop on the boat and it was recently serviced. 5) No idea! 6) What do you mean by "WOT"? There is no ballast in the boat and there is 4 poeple.. Cheers fr your help. Joel |
#113
Hi Guys,
I have started a new thread.. http://www.mastercraft.com/teamtalk/...445#post915445 Sorry for jacking this one!! ![]() |
#114
WOT= wide open throttle. I assumed you were opening up the throttle when the revs jumped up, not the boat doing this on its own, which would definitely be a slipping issue. |
#115
Machine shop is afraid to crack the strut, won't touch it. Lag bolted it to a 4x4 and 2x4 side by side, used a shovel handle through the tube, couldn't get it to budge. Tomorrow I will take it to my local marine shop (not my favorite option as I have mentioned before) but they have a pretty good metal/body guy.
I would love to give this shop more business but how can I justify it when their store prices make west marine look like a bargain, they quote me "like 700 or 800" for a shaft, and their "alignment" left my shaft riding on the log and two hands to turn the prop. I wish their metal guy had his own shop. Last edited by Scot; 03-14-2013 at 01:34 AM. |
#116
ground the strut base down with emphasis on the corner that needed to come up. Didnt line up. Put a washer on the opposite corner, still didnt line up.
Then I bolted it on tight, put a pipe wrench on it with a come-along to the trailer axle. Got it nice and straight this way. Took it apart and when I went to put it back together a little bit later it still lined up crooked. Did the brass spring back? Should I try this again with heat? Cant get this damn thing to line up! I am tempted to just scrap this shaft and strut even though I just spent a hundred bucks on new bushings for this one. |
#117
Call them for underwater gear. When I bent my strut I called them and just gave him year make and model. http://www.elberts.com/underwatergear.htm
Gone, surfing. |
#118
May have to over-correct when you torque it to end up true. Wouldn't have thought it would take so much effort.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WEEKEND WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#119
Think I got it now. My torquing worked again but it slipped back a bit when I loosened it again. So I applied 5200, snugged up the 4 outer bolts and torqued it until the shaft touched the opposite corner of where it used to ride. Tightened the bolts and took the pressure off and it sat right where I wanted it to. Put the four inner bolts in and snugged them up. Put a couple more cranks on the winch to bias the shaft toward the opposite corner of where it rode before and tightened all bolts. I will keep the winch where it is for a day and hopefully when I release it everything will be close to center. I am banking on a little play in the bolt holes (not much), the 5200 holding everything in place, and a little bending of the strut. After I release the pressure I am going to watch the shaft for a day or so and make sure everythin doesn't recoil to its old position. If it does it's no more mr. nice guy- heat, a lot of pulling and whatever happens, whether its straightening this thing, breaking it and buying a new one, or ripping the bottom of my boat apart. I sure hope its not the last one, but hopefully everything works the first time. |
#120
I found a machine shop that is willing to fill the grooves in my shaft and turn it back down.
Anyone have any input as to whether it is a good idea or not to try this? If not I will probably just run this shaft as is. Not much play in the shaft once its in the strut, just want to reduce vibration if possible without replacing the shaft. Also, does anyone know if vaseline will damage the cutlass bushings if I use it to check rotation while dry? I wouldn't think so but my transmission manual warned against using it on the seals as it can damage the rubber, not sure if that applies to something like these bushings. |
