#101
Back on the thread jack question
The boat rolls 4k plus seems to bounce off rev limit and takes 11 seconds to hit 30 mph and winding it out. The second vid shows the engine falling off at 4+k and tops out -40 mph. Peaks at 4800 I am very curious that the boat is struggling so hard to get to 30 but is reving high rpm. Before y'all flame me 1) Explain why the engine is screaming and takes forever to get to 15-30 mph. Is this a low HP engine? 2) instead of just dropping the throttle to the floor can the boat be driven normal rolling into the throttle and the prop staying somewhat even with rpm all of the way to 36mph. 3) did this just start doing this or is the boat new to you. 4) is the correct prop on the boat 5) what is the factory rev limit 6) why at 30 mph to wot does the boat creep up to speed. Rpm turning (screaming) and boat not accelerating is a sign of slipping. It looks like a tranny problem since you are spinning 4k and the mph starts increasing extremely slow. My boat will be up to 36mph in 6-7 seconds. 11 seconds we will be well over 40 possibly 46-47 mph on GPS I would check tranny fluid color, smell, level, etc Next I would evaluate the proper use of the boat under 4k rpm If the tranny and engine perform correctly then agree there is obviously other issues. A TPS that has a bad spot can confuse the ECM and can either lean out the engine or flood it. And there are other sensors that will cause the engine to bounce at any rpm. My main concern is the fact the engine screams and the boat doesn't want to come up to speed. Is it full of ballast, weight, etc there is no reason for the engine to take 11 seconds to come up to speed. 4k rpm and keeping it while accelerating is not a sign of bogging down. Engine is spinning strong and has weak acceleration.... Then we have 4-4800 rpm bouncing. Are we hitting rev limit???? If yes then you do not have engine problems. If your rev limit is not hitting then you more than likely have a sensor failure. Again boat has poor acceleration with high rpm. I need an explanation for this.
Rollin' Gangsta Style Quote:
#102
the fact that the speedo on the left stays at zero even though the wind and water sounds seem to say that the boat is moving and the fact that the right one never moves, it seems that they are clogged/malfunctioning.
We need more info from the poster. Is your left speedo accurate? What was your throttling? When the motor is screaming are you at WOT or less? |
#103
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#104
'96 ProStar 205 SD LT-1 |
#105
#106
I would be careful about using the base of the strut to judge how off center the body is. Ive seen some very sloppy castings that would give you misleading numbers. I would also make sure youre measuring off of something perfectly flat, as someone pointed out. Got granite countertops?
Remember that being 1/4" over on the body wouldnt require a 1/4" adjustment on the base. Probably closer to 1/8". Still, thats a fair amount to compensate for, so you may want to get it closer before trying to make fine adjustments (grinding, washers, etc). See if you can have a shop bend it back for a reasonable amount. If not, then a new one is a consideration... but remember that even new ones may need some massaging to line up to the log (the one I altered was brand new).
PCM 351w, 350hp |
#107
I know my measurements are not accurate, but we aren't talking 1/16", this thing is bent! Stand above it, close one eye, and its clear. Tried to get a good pic to show it but couldnt get one that proved my point. Going to the machine shop tomorrow morning. Cant imagine why they cant straighten a piece of brass but if they say no its option 2b. Will lag bolt it to a couple 4x4s and use my hands and feet, get it as close as I can.
Apparently this is not a simple replacement, skidim.com says these older struts can vary, my best bet may be marinehardware.com with all dimensions on their worksheet? Might be pricey, I dont know. Any ideas of other places to look? I am sure I can bend it if need be, I just trust the equipment in a machine shop more than my make-do garage methods. Biggest concern is keeping the tube round under pressure. |
#108
I have the boat in gear in both videos, so i am accelerating. The fist video is from a still start (speedo doesn't work in this video but i am moving), and the second video is accelerating from 3000rpm. It is not the rev limiter. The reason for the high rpm is barefooting. I have owned the boat for 6 months and put 20 hours on it, i have barefooted behind it numerous times (and the day before this started happening) and it has never done this before. The speedo is temperamental, sometimes it works, other times it doesn't. |
#110
There are very loud knocks when the revs drop. Again, i have no idea what this is!
