Old 01-30-2013, 11:00 AM
98Prostar205 98Prostar205 is offline
Boat: 1998 Prostar 205
Removing Fuel from Tank
Ok, I know someone on here has a creative way to remove the fuel from the tank on their boat. I need to remove my tank and it is at least 3/4 full. I am replacing the exhaust flanges on the boat. I know that this can be done without removing the tank, but when I was inspecting the exhaust hoses, I noticed that the carpet under my fuel tank is very dirty and my MCOCD won't let me just put the panels back in place and cover it up.
I don't have a pump and if there is a way to avoid having to buy one that would be awesome. My initial idea is to push a hose through the filler hose and into the tank. then I would pour fuel into the hose and pinch it off. I would then place this hose into a gas container and "un-pinch" it to let it siphon most of the fuel out. Will this work? Any better ideas?
Old 01-30-2013, 11:38 AM
You can get either a cheap pump or siphon that will get the job done.
http://www.amazon.com/Triple-Seven-S.../dp/B000BG1X54
http://www.harborfreight.com/catalog...esult?q=siphon
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 01-30-2013, 12:23 PM
Barefooter92's Avatar
I had the same issue last season. I went to lowes and purchased a 1-1/2" diameter clear hose one that would fit in the filler hole and shoved about 10' in the tank held the end with my thumb and pulled it out half way and what do you know it started to flow. Only works with a full or near full tank. I was able to get about 75-80% empty enough to move it around by hand to clean behind. Once I got it all the way out I pulled the fuel sender to fix the floats and pumped the rest out with my turkey fryer oil pump. Needless to say it now says fuel only and not fry oil!
Old 01-30-2013, 10:07 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 1994 Prostar 205
Not sure if this is long enough or not but I have one of these to put fuel in the boat from a 5 gal and it works great. May take a little while to get 30gals or so out though. They sell them at Academy or Bass Pro.
http://www.overtons.com/modperl/prod...r-Pump&i=20769
Old 01-30-2013, 10:36 PM
Same thing at Harbor Freight, if you don't want to wait.
Old 01-30-2013, 10:44 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
A little gas in the mouth never hurt anyone... siphon it out like a man!
Bailey
'02 X-9
Lake Blue Ridge
Old 01-30-2013, 10:49 PM
Doesn't taste good, especially with 2 cycle oil in it.
Old 01-30-2013, 11:07 PM
These work great. I had to break down and get a new hose for mine as it finally got too old and wasn't flexible enough to work well.
- Peter
TIRE & WHEEL SALES
WHEEL SPECIAL
Old 01-31-2013, 09:01 AM
Thanks for the responses! This forum is great!
Old 01-31-2013, 09:41 AM
My original one worked fine until something happened and the glass bead inside chipped. It stopped pulling vacuum and actually fell out, so I replaced it. I'm pretty sure the more expensive ones have a stainless ball inside.
