Old 01-29-2013, 02:08 PM
drschemel's Avatar
Boat: 1990 Tristar 190 closed bow
wow! I have the interior out of my TriStar and will freight it to Viper ($330 shipping one way) to have the seats redone. They seem to know what they do and are priced way under my local upholstry shops. But after seeing the condition or your boat, mine is pristine! 22 years of indoor storage has helped a lot. Good luck on your project. Jim at BAWS can reproduce your decals if you want to keep the origial look.
Old 01-29-2013, 02:23 PM
Lumbergh's Avatar
Lumbergh Lumbergh is offline
Boat: 1991 ProStar 190
...It looks like you are doing a good job of limiting yourself to repairing the necessary issues while keeping an eye on resale. This can be a difficult line to walk. Keep up the great work!
Sage advice. A true life lesson there!
Old 02-01-2013, 11:33 PM
lakeoz tristar's Avatar
lakeoz tristar lakeoz tristar is offline
Boat: 1990 Tristar 190 and 1998 Baha Cruiser Mach 1 290
The pics are from the removable floor sections still need to do the cut outs but other than that they are good to go.
got the three removeable floor sections done and the driver side (no pics yet) almost done with the carept. Still have to do the front sections which should be easier once I have the floor pieces back in over the gas tank. Also spent some time cleaning off the gas tank it was a mess. And then I still have the panels that hide all the wires in front of the two forward seats but I think I need to do some glass work on them first.
Also want to *** a new swim deck may thinking of the same type, found some non slip matting like what is already on there for pretty cheap, might see how this one cleans up.
Picture # 2 See the exhaust hole fitting, Does anyone know what that is called or where to get a replacement? I have one that is pretty beat up if not too hard to find might get a replacement.
To answer when I got this boat- I got this boat Jan 2012. Was in pretty rough shape I guess but I thought the price was right until someone posted that tristar in Des Moines this week DOHHH...
12 more payments on my other boat and I may be looking for a upgrade mastercraft
I consider this my learn everything on boat.
Old 02-01-2013, 11:40 PM
http://www.jamestowndistributors.com...On+Hose+Flange
Guess I asked too soon found them.
Old 02-02-2013, 12:58 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Well done my man. I did almost exactly what you've done on my former TriStar. Your replacement carpet even looks exactly the same!
Great pics also to document your work. Keep 'em coming.
As for the side decal, I personally like the stock look with the gray shadowing.
Old 02-02-2013, 10:27 PM
Got all the carpet on the floors still have to to the panels under the dash in front of each seat. But like I said before I might need some fiberglass work on them first Starting to come together.. hope I remember where all the screws go!! Wish I took more pictures of the floor before I took it all apart.
Still have alot to do but I can see the progress and hopefully the hardest part is done.
Old 02-02-2013, 10:39 PM
wheelerd's Avatar
Boat: 2005 X2
You were asking earlier about the exhaust ...
Not sure if your need the flapper or the flange but SkiDim has them both.
http://www.skidim.com/departments.asp?dept=1015
Also, you said you might need to do some glass work on the panels under the dash -- are they cracked or what? If so, just a couple layers of fibreglass cloth will do the trick but don't make them too rigid as they need to be able to flex a bit to be installed as I recall.
Old 02-02-2013, 10:53 PM
Thank You I actually needed the part that goes through the floor, pic attached. I have one on order.
Yeah the panel its pretty flexible but there is some chipping around the edge I guess its all going to be covered with carpet. I might just leave it alone at this point. It is the part that sits right under the steering wheel.
Old 02-02-2013, 10:58 PM
Here this may help what I am talking about.
Old 02-02-2013, 11:25 PM
wheelerd's Avatar
Boat: 2005 X2
Gotcha. Maybe you could build up the panel edges with some premixed resin and chopped fiber.
