Knock Sensor Removal Trouble
Winterized the boat about a month ago. Drained the exhaust manifolds and port side block plug, pulled the thermostat, and then ran 5 gallons of rv antifreeze out of a bucket through the entire engine. There was definitelt]y red antifreeze coming out of the exhaust.
I've been doing some reading on this site and it seems that everybody removes the drain plug on the starboard side of the block as well. Since I use the cheap rv antifreeze, I figured I'd do the same just in case the antifreeze was diluted too much. On my engine, this drain plug has the knock sensor on it. I got a 7/8" wrench and started turning the knock sensor to remove it. My problem is that the center hex head spins, but the outside housing and the threads in to the block do not. Is there a trick to removing the knock sensor? Did I damage it? The center hex does not spin smoothly, more in rough steps. Below is a link to skidim for the knock sensor that I have. http://www.skidim.com/prodinfo.asp?number=R020027 |
I've got the same sensor and just loosen with a wrench as you describe; never had just part of it turn, so it sounds like something isn't right. I'm sure a better wrench will jump in here shortly.
sounds like time for a new knock sensor. appears outer housing loose from over torquing when installing over there years. It only has to be snug.
Loosen is up with a pair fo slip-joint plyers on the outer body. I would then suggest replacing it.
What he said^^^^^^
I 3rd what MLA suggests.
Thanks guys. I just wanted to make sure before I took pliers or vice grips to the outer housing.
ditto, the outer housing is peened over to the inner part. Small pipe wrench on the outside should take it out, then replace. I take mine out every year to winterize.
I was njskier on here. |
and the wives laugh our boating addictions.. ![]()
I don't know what slip joit plyers are, but I would use dogs, or channel dogs to be more specific,
