Quick help, LATE OFF SEASON WINTERIZING
Quick help....I just bought my Mastercraft from a dealer that kept the boat in a heated facility therefor they did not fully winterize it (i.e. no antifreeze through coolant system. Here in VA we only have a couple weeks of cold weather left. However over the next few nights it is supposed to get down into the mid to upper 20's. I would have to leave work early today in order to get it done...but should I go ahead and drain the block and run antifreeze through the boat just in case?? Or would I be fine....
Is it stored outside?
I would at least drain it and pull it around on the trailer to make sure you get the waters out of the little pockets in the engine. I'm overly cautious about these things. But, then again, I have never had a block freeze as a result of my method.
Previous: 1993 Prostar 205 Red 1998 Closed Bow Ski Boat, Ford 351, 310 hp, Acme 4 blade, Perfect Pass SG. FAQ Tyler Ski Club To me, this forum is about love of inboard boats. It is about the sharing of information and, on a good day, some humor. It is not about post count, brand of boat, or any other superfluous labels that lend themselves to a false sense of superiority. Please, respect one another, try to pass on accurate information, and keep your eye on the ball. |
just draining the block should do it. Temps in the low 30's i wouldnt worry but 20's is a different matter. Definitely drain.
David 2008 X2 MCX ![]() 1999 Maristar 210 (sold) 1996 Bayliner 2050 |
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
Pull the hoses and turn the engine over a few turns to get the water out of the pump housing. Pull the kill switch/safety lanyard before you do this. Pump housings aren't as thick as blocks.
