Go Back   TeamTalk > Classifieds Buy/Sell > For Sale: Boats
Old 01-24-2013, 07:34 AM
linemanz linemanz is offline
Boat: rinker
x7 hour meter has no power
Found an x7 2002 model and the hour gauge on the tach does not turn on,is this fused?lookin for ideas here all the other gauges work fine,need some ideas on whay to look at,is there a way to turn it on/off./
Old 01-24-2013, 08:50 AM
Boat: 2002 Prostar 209 - SammyD Edition
if it were my guess it would be the gauge. They are single interchangable plugs into all of the gauges so unlikely its a wiring issue. Most likely thats the issue that they are about 80-100 bucks online. Is the tach itself working and just not the hours?
Old 01-24-2013, 11:43 AM
MCOCD@13 out of 10
check the ECU for hours and then get a new meter and make a note of hours from ecu.
Old 01-24-2013, 03:58 PM
petermegan's Avatar
*2. I bought a tacho on ebay for my 2000 Prostar and found it was for the later brainbox. Tacho worked fine but nothing showed in the lcd screen. Is it the original gauge? There must be a separate wire for current to the gauge, as I believe the ignition only has to be turned on to clock up hours.
Old 01-24-2013, 09:33 PM
Boat: rinker
Yeah the tach works fine,just no display on meter,I called a mastercraft dealer and they were around 100 bucks for a new factory tach,yes it is the original one in the boat.kinda a pain in the *** to deal with.I was hopin it was just a fuse or something but its not it comes straight from the ecm box.
Old 01-24-2013, 09:45 PM
huh. To my knowledge all the plugs are interchangable for the dash. Think we are overcomplicating this. It should just be.........buy a new one and the hours will show up. Greatlakes and ebay has some under 100 bones. Either that or find a fellow tt member in your area that will let you plug your tach up to theirs to test it.
Old 01-24-2013, 09:47 PM
MCOCD@13 out of 10
Yes but the ECU will tell what hours were run at what RPM's...iirc.
