Old 09-13-2005, 02:37 PM
76stars_and_stripes
Lifting boat 76 stars and stripes
Hi,
I was wondering how to lift my 76 to make a repair. I found some damage (a crack in the gel coat) on the side that needs some attention, and it has to be off the trailer to fix. Any body got any ideas. Boat has no lift hooks.
Thanks
Old 09-13-2005, 03:22 PM
T Scott T Scott is offline
Boat: It's always changing! X-Star-Prostar190/205-Maristar
Sounds like you will need to lift it using a sling. It seems as if you will need to find a strong enough hoist, forklift, etc. to lift it up.
Old 09-13-2005, 03:31 PM
rodltg2 rodltg2 is offline
Boat: 2017 PS
Send a message via AIM to rodltg2
by no means do i have any experience doing this , but what about using a forklift to raise the end you need to get.
Old 09-13-2005, 10:06 PM
John 3:16-18
Old 09-14-2005, 01:48 PM
76stars_and_stripes
Is the bottom of these boats strong enough to lift the back up from the bottom side, flat across the bottom, like say a 2x4 or something across the bottom from side to side with a jack underneath? How much do these boats weigh?
Old 09-14-2005, 05:58 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
I'd hazard to say that any flat hard lifting beam would not be good, as the boat is not completely flat and the load will be concentrated at the lowest point of the hull, even in back. 2x4 is way too light also.
If no lifting rings, you need 2 nylon slings. Jack the boat up enough to get the slings over the bunks and basket pick it with the lifting machine of your choice (forklift, crane, loader, 2 stout tree branches and comalongs!).
Old 09-15-2005, 11:13 AM
76stars_and_stripes
Thanks,
Got 2 slings today, getting ready to try it out. Will let everybody know how it went. Hopefully I'll still have a boat at the end of the day.
Old 09-15-2005, 11:14 AM
PointTaken's Avatar
PointTaken PointTaken is offline
Boat: 1991 prostar 190
Good luck. Hope all goes well.
Old 09-15-2005, 01:46 PM
76stars_and_stripes
Success!!
Thanks everybody for your input. Everything went perfect. Used a floor jack and a 4x4 to lift boat about 1/2 inch. Ran a lifting strap through, then hooked to the bucket on the back hoe. Made my repair, and it looks good as new. I'll try to get some pics of my boat on here as soon as I can.
Thanks
Old 09-15-2005, 07:46 PM
John 3:16-18
