Old 01-30-2013, 11:43 PM
pbgbottle's Avatar
pbgbottle pbgbottle is offline
Boat: 1988 tristar 190
Thanks for the update. I would love a pic of it installed. Cheers.
1988 mastercraft tristar (open bow).
Old 02-03-2013, 07:55 AM
tockit's Avatar
tockit tockit is offline
Boat: 1989 190 Tristar
Would the stock voltage regulator work Ok with this alternator?
Old 02-03-2013, 08:32 AM
Cloaked Cloaked is offline
Boat: MasterCraft
Originally Posted by Tristarboarder View Post
Well, here it is, my shiny, new alternator...........I was clever enough to ask him if he got a part #, and he gave me one. FINALLY! So, I called DB back and got this beauty, a 105 amp version, 1-wire that should bolt right on. Now to see if it actually fits and works...
What is the part number? Same as posted above or a different (final) part number? Thanks
Old 02-03-2013, 11:38 AM
Tristarboarder's Avatar
Boat: 1990 Tristar 190
Part # is ADR0334. Of course everything turns into more of a job....The main long bolt that goes into the block doesn't fit through the hole on the alternator. But, the guy at the auto electric shop, who was trying to sell me a Marine Prestolite for $250 was gonna have to drill out the hole on that one to make it work as well, so I am going to take it down tomorrow and have them do it to this one....after that it should mount right up.....will keep ya posted. Why wouldn't they volt reg work with it? I didn't consider that, but assumed it would?
Old 02-03-2013, 12:00 PM
tockit's Avatar
It may, but I've never upgraded to a higher output alternator, so I wasn't sure.
Old 02-03-2013, 03:18 PM
j.mccreight@hotmail.com j.mccreight@hotmail.com is online now
the prestolite (motorola) alternators that came on the Indmar had internal voltage regulators, if it's a PCM they had external regulators.
James
Old 02-05-2013, 06:11 PM
Finally installed
Well, here it is, installed. It bolted right up, everything fit the Indmar/Ford 351W brackets. I took it down to my local auto electrical shop again to have the bolt hole drilled out, but he simply swapped the outer case with one he had on the shelf with the bigger hole attached, no cost.....Boat is still Winterized, so I haven't fired it up, but with a new belt, everything is lined up good and tight. On to my next challenge....
Old 02-05-2013, 06:58 PM
pbgbottle's Avatar
looks good thanks
Old 02-09-2013, 10:38 AM
tockit's Avatar
Alternator looks really nice!
Old 02-09-2013, 10:41 AM
tockit's Avatar
Tristarboarder,
I just noticed in your picture that you're missing the spacer that goes on the bolt in between the top alternator lug and the engine cylinder head. You can see where the old spacer used to be on the front of the cylinder head because the black paint is missing around that top bolt where it screws into the head.
That missing spacer might allow your alternator to drift slightly forward and aft during operation and cause your alignment to change, belt squeal, etc.
Might be something you want to check into before the season starts.
