Old 02-12-2013, 01:03 PM
kyfooter's Avatar
kyfooter kyfooter is offline
Boat: 2013 197 WTT / 1992 Barefoot Sanger
X-25 length/width including trailer
Can someone please post the total length and width of an X-25 including trailer? The specs section on the main site does not show the data. I'm building a new garage, and the tentative plan is for it to be 32' wide and 30' in length, but by the time it's framed and bricked the actual inside dimensions are likely about 18" less.
If you have the dimension with the tongue folded as well as in its normal position that would be great. Deck in the down position is ideal as well.
Just second guessing myself, and wondering if I should go 32' long x 30' wide instead of 30' long x 32' wide. I'll have storage behind the boat, and don't want to be left squeezing between things.
Don't own an X-25 yet...just figured I would build for future purchases just in case.
Thanks.
Old 02-12-2013, 01:29 PM
FourFourty's Avatar
Boat: 2018 XStar that's trying to be a 40th.
You are in luck
I had to do this when I built my garage.
Boatmate trailer, and '11 X25....
Length- Platform in Normal position, and tongue folded. = 25' 8"
Width- Including guide poles. = 9' 8"
Width- without guide poles. = 8' 7 1/2" (outside of rubrail). Trailer is 8' 6"
You will want your garage door to be 11' wide and 11' high if you want to leave the guide poles on, and the tower up.
If you are going to fold the tower.... 11' wide and at least 8' tall.
I have backed my boat in through a 10' wide, and 8' tall door. However the guidpoles were touching the door seal on both sides, and it just barely cleared on the top with a folded ZFT3. (which might not be the same height as a folded ZFT2 or ZFT4)
Old 02-12-2013, 08:49 PM
kyfooter's Avatar
Thank you!
