Old 01-19-2013, 05:30 PM
JaredOSU JaredOSU is offline
Boat: Mastercraft Prostar 190 351 Windsor 1:1 Borg Warner
1:1 transmission
If an engine is at idle, should the drive shaft be turning? I hit ground (gravel/mud) last summer is this dry state of oklahoma. And it kind of seems like the transmission, while in idle, is trying to make the drive shaft turn. Also, it acts like it slips at times while under load (driving).
Old 01-19-2013, 05:41 PM
1redTA's Avatar
1redTA 1redTA is offline
Boat: 1981 MasterCraft Limited 351W slot
a lot of boats have the shaft turning in idle according to this site
1981 MasterCraft
19' Skier 351W PowerSlot Deluxe
Long gone is the Trans AM
Old 01-19-2013, 06:31 PM
Yeah sorry, I meant when the engine was at idle and was not in gear.
Old 01-19-2013, 07:21 PM
MCOCD@13 out of 10
yes, it is normal, the fluid when cold puts pressure on an internals of the transmission.. Miss Rita explained it here. If there's no pressure against the prop the shaft can turn... many discussions about the here.
Miss Rita explains it in this tread http://www.mastercraft.com/teamtalk/...482#post889482
Old 01-20-2013, 12:08 AM
Might need to check your transmission fluid level if it seems like its slipping, maybe even replace the fluid if it's been 100 hrs or you don't know how long its been. (Dexron III or equivalent)
James
Old 01-20-2013, 10:05 AM
MCOCD@13 out of 10
The slipping part - you may want to have checked...if you feel it's slipping...that part I did not focus in on - I am with J.M on the fluid change. If you have the 450 transmission - it has a filter... hard to get to - have to pull shaft to reach - even if you have small hands. A prop strike is not good - how hard did strike the ground...did prop get damaged? Is shaft still straight?
When you say slip - while underway - loss of speed and increase in rpm's?
Old 01-20-2013, 04:54 PM
east tx skier's Avatar
Boat: 1998 Ski Nautique
I was made to understand that, over time, the clutch pack develops a bit of a glaze that allows the shaft to turn in neutral. Not uncommon at all.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 01-20-2013, 07:19 PM
I bent the prop pretty badly when I hit the ground. I was going slalom speed and hit ground a little beyond the last gate. I was on a course & lake that I ski down once every few years in eastern oklahoma. And at the start of last season I noticed some noise near the prop shaft seal. I called SkiDIM and they said that the shaft was likely bent. So I replaced the drive shaft and seal. I took extra-special care to make sure I lined the engine and drive shaft to less than .003". So I replaced everything but the cutlas bearings. I even put a brand new steering system in the boat.
