Old 01-18-2013, 01:12 PM
Originally Posted by 19_Skier View Post
used 3M rubbing compound and 3M finesse-it polish with a variable speed buffer. Before and after photos. It takes time, patience and your arms will be sore but so worth it in the end.
Nice work.....
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 01-18-2013, 05:48 PM
Tristarboarder's Avatar
Boat: 1990 Tristar 190
What grit of paper did you use? Wet/dry obviously?
Old 01-18-2013, 05:51 PM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
I just finished mine a couple of weekends ago. I wetsanded the transom with 600, 1000, 1500, and 2000, then used a makita wool pad and 3m perfect it rubbing compound, then used a 3m perfect it ultrafine foam pad with 3m finesse it finishing compound. I used a neiko ct6101 for the buffing and polishing.
2003 X2
Old 01-18-2013, 06:47 PM
Wow!.....great results.
- Peter
TIRE & WHEEL SALES
Old 01-19-2013, 12:54 PM
orbeamlb's Avatar
orbeamlb orbeamlb is offline
Man that looks great! Nothing shines like Black.
Old 01-19-2013, 01:21 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
Your results were great but you did a lot of unnecessary sanding. 3M Super Duty Compound with a wool pad will remove the 1000 grit scratches so you can eliminate the 1500 and 2K sanding.
Old 01-19-2013, 02:47 PM
Would you still use the 600 to start, then the 1000, followed by the 3M Super Duty with a wool pad? Or just start with the 1000 then move on with the compound etc?
Old 01-19-2013, 03:50 PM
JRW160's Avatar
Boat: 2003 X2
I started with 600 because I made a few gelcoat repairs and used the 600 to sand those down. If you just have oxidation, I think starting with 1000 would be fine.
2003 X2
Old 01-19-2013, 05:56 PM
My goal is to remove some shadowing from old to new decal placement. For those of you that have removed the shadowing, did you tape over the new decals or what? And then use the 1000 followed by the compound etc?
