Old 01-18-2013, 10:49 AM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
Originally Posted by east tx skier View Post
Did you overheat at some point?
That's what I was thinking. Is this boat "new to you"? If not, when did it get this way?
Old 01-18-2013, 10:51 AM
GoneBoatN's Avatar
Originally Posted by clc900 View Post
I will plan on replacing it. I will run it this weekend and check the temperature of each side before I replace the hose. Once I get it off I will inspect the inside and try to see what caused it to warp.
Thanks guys!
I'm suspecting you are going to find the hose damaged inside. How does it compare to the other side in terms of softness and flexible?
Old 01-18-2013, 11:07 AM
93Prostar190's Avatar
I would replace ... and then keep checking the new one ... it warped ... maybe for age or bad material reasons ... but it also could have warped due to high heat ... if it warps a new hose then it means that you need to consider checking your manifold to make sure there is no restriction in water flow which would help offset the heat ....
Just my $0.02 ...... not overly serious but maybe a "clue" to something else going on ....
2008 Prostar 214 MCX
Old 01-18-2013, 11:17 AM
MCOCD@13 out of 10
we need cloaked to post his picture again...
Old 01-18-2013, 11:20 AM
Which Pic?
Old 01-18-2013, 11:48 AM
I will jump on the bandwagon and say I would replace that hose. At least remove and inspect.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WEEKEND WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 01-18-2013, 12:22 PM
GoneBoatN's Avatar
Makes me think we desperately need a bandwagon smiley in the Smiles.
Old 01-18-2013, 12:24 PM
Very good idea.
- Peter
TIRE & WHEEL SALES
Old 01-18-2013, 02:43 PM
clc900 clc900 is offline
Boat: 2006 Maristar 200, 350MCX, VDrive
Boat is recently new to me. Hasn't had any other signs of an overheat. I will check into it more this weekend.
2006 Maristar 200
350 MCX
V Drive
Old 01-26-2013, 10:47 PM
Removed the hose today and this is what I found. The hose obviously restricted flow of the exhaust. The silencer shows some heat damage as well. Besides replacing the hose is there anything else that I should check out?
I'm not sure why the hose collapsed. Could be heat. Could be it was installed incorrectly? The hose is quite a bit longer than the other side. It's almost like the hose was kinked in to make it a bit shorter so it would fit better when it was installed.
Also, the path from the manifold to the silencer is a bit offset. It is not a straight path like the other side is. The exhaust manifold is offset to the outside of the silencer. Could this be why the outside of he silencer inlet shows heat damage?
Just thinking out loud here. Let me know if there is anything else I should do or check besides getting a new hose.
Thanks!
2006 Maristar 200
350 MCX
V Drive
