Old 01-15-2013, 10:26 AM
Boat: 2002 Prostar 209 - SammyD Edition
f you are a serious tournament skier, go with a boat that has Zero Off. The slalom pull is a lot different than Perfect Pass StarGazer, for slalom. Zero Off is GPS based, and PP StarGazer is RPM based. I had the Perfect Pass in my 2002 197 TT, but have the Zero Off in my 2010 197 TT boat. For tricks either one is fine, although Zero Off gives a better pull and can provide a more custom pull due to the letters (A, B, C) and numbers (1, 2, 3) option. Those same letter/numbers combination are also available for slalom and jump. Perfect Pass does not offer those customized settings. A1 is the softest pull, and C3 would be the strongest pull. If you are not really a serious tournament skier, then the Perfect Pass StarGazer is a great speed control. The Zero Off pull for slalom and jump, is a lot different than PP StarGazer.
The problem you are describing for the pulls with PP as compared to SG is remedied with zbox so I've heard. Zbox has similar settings as the ZO. All of this of course coming from a non skier but I did stay at a holiday inn express
Old 01-15-2013, 03:13 PM
03 35th Anniversary's Avatar
03 35th Anniversary 03 35th Anniversary is offline
Boat: 03 35th Anniversary LQ9 Supercharged
Originally Posted by 02ProstarSammyD View Post
stargazer?
No
3 Event Wake-Pro
Old 01-15-2013, 06:55 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: A 2009 X14
Originally Posted by Tricky1 View Post
If you are a serious tournament skier, go with a boat that has Zero Off. The slalom pull is a lot different than Perfect Pass StarGazer, for slalom. Zero Off is GPS based, and PP StarGazer is RPM based.
Unless I am missing something, Perfect Pass SG is not RPM based.
'97 Prostar 190 - LT-1
Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar.
Old 01-15-2013, 11:14 PM
TNH2oSkier TNH2oSkier is offline
Not missing it at all.... the sg is gps, it uses rpm to get it up and close to speed then gps locks on, all before you hit the gates if everything is set up correctly.
The pull from sg/zo is different, but the difference is getting smaller.
Old 01-16-2013, 11:46 AM
TayMC197's Avatar
TayMC197 TayMC197 is offline
I was about to say, my SG uses GPS. I throttle it up by hand, it locks and takes over.. No paddle wheel.
It also has a million settings to perfect my pull, it allows me to adjust the weight of people in the boat, weight of skier, what line length, etc. I'm no tournament skier but I have friends who are and it runs the course just fine. No complaints yet.
Also, pulling without cruise control is fine. The prop setup on these boats keeps it from deviating to much when the skier is pulling. Takes little time at all to get comfortable driving that way. Its how I learned back in the day.
Old 01-16-2013, 12:48 PM
yippikaiyay's Avatar
yippikaiyay yippikaiyay is offline
Boat: Prostar 197, 2008
Originally Posted by WindBraker View Post
Hey guys. I'm about to pull the trigger on a 5 year old ps197. This will be my first ski boat. The boat is in excellent condition...very clean. One thing it does not have is 0 off or perfect pass. Do you think this will be a big deal? I haven't skied since I was a teen (now in my 30's) but plan on skiing my brains out once I get the boat.
Also, any words of wisdom, or thoughts on the 197 will be appreciated.
Thanks in advance for your input.
I upgraded my MC to an '08 197 a few years ago. I love my boat. If you're going to 'ski your brains out', you'll love it too.
Old 01-17-2013, 12:24 PM
yeahmooney's Avatar
yeahmooney yeahmooney is offline
Boat: Prostar 197 MCX Red, White, and Blue
I have a 04' 197 with Perfect Pass Wakeboard Pro. If you haven't skied since you were a teen and are now in your mid 30's the Perfect Pass with be fine. If you look around this board you will find that any type of cruise is a marriage saver.
Old 01-17-2013, 12:34 PM
mark g's Avatar
mark g mark g is offline
Boat: 87 prostar 190
Had the same ideas when I upgraded, had a 88 prostar 190 which I put perfect pass on and said I would never have another boat without it, I bought a 2005 prostar 197 with cruise on, was going to swap it out but to be honest the cruise works as good as perfect pass did, difference is you can't alter the pull characteristics with mastercraft cruise, if your not short line skiing on the course I wouldn't worry.
That's if you have mastercraft cruise not sure if it was standard
