#51
Lots of great advice I won't repeat. One I didn't see:
Whenever you stop, touch the hubs on the wheels. If it's really hot, you have a problem. Other than what others have said, gas up & p before you go.
Some mornings it just doesn't seem worth it to gnaw through the leather straps. -Emo Phillips |
#52
Good point on hub temps. Any time I tow the boat and stop, I make sure to walk around the back end of the boat and check tires, hubs, trailer connector, wiring connection and safety chains.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#53
Not quite ready to sell it yet...I got a new spare, have another spare, 2 year old tires, tie downs, jack and a lug wrench. The weather forecast is good. Just getting 12 foot bunks and another crossmember, not a fun boat trip. Temp here is in the 20's at night, so I think this is a good time to finish this project.
#54
Watch out for semi tire caps that have peeled off the tire. I was in the wrong lane at the wrong time. Kicked it up. Hit the fender, lucky it glanced off and there were only black marks that I was able to rub off.
#55
There are alligators everywhere.......not just down south.
#56
We tow my buddies boat from NY to FL & back every spring. We do all the stuff that was mentioned earlier but instead of spare bearings and races he carries a spare hub assembly.
1996 ProStar 190 Still slummin' behind PP Chippin' away @ the BLUE LOOP |
#57
My experience has been that an automotive scissor or bottle jack is often not hefty enough for a boat or travel trailer. With a vehicle you're typically just lifting one corner. With a trailer you're lifting the whole side of the unit, ie. much more weight.
I carry one of these in my Yukon since I often tow a 28' travel trailer as well. http://www.basspro.com/Quick-Change-.../product/9071/ You just wedge it under the axle, pull forward a bit, and the jack rotates under the axle and lifts it up. I place a chunk of old carpet between the jack and the axle so it doesn't scratch the axle.
"For every complex problem there is an answer that is clear, simple, and wrong." (Henry Louis Mencken) 2005 X2 Viper Red, MCX, Acme 1285, PPass (previous) 2001 X5, 1991 TriStar 190 |
#58
I've seen those, but was never sure they actually worked. Have you had to use yours?
1998 Maristar 200VRS |
#59
I've never needed it on the road but I've tried it out at home to make sure it worked. On soft ground I would image that it might need something under it like a chunk of 2 x 4 or plywood since it has a small footprint.
#60
voodoo |
