Upgrade to Captain Seat
Hello Fellow TT members,
Here's to a safe and happy 2013 boating season ahead! I have a 95 ProStar 205 and I have been thinking about whether or not its possible to upgrade the captain (driver) seat. In particular, I would like to update it to where the bottom cushion moves up and lifts the bottom portion creating a hump to sit on as newer models do. Has anyone tried to do this on an older model? Any advice on how to or where to go to get this done would help (if possible). Thank you! Jim
Held to a Higher Standard......Let's Face It Steak Costs More Than Hamburger - MASTERCRAFT |
I updated our 95 Barefoot 200 with a new seat from an 05 X-star. the modern seats use a much smaller footprint from the wide layout you currently have, so new holes need to be drilled in the pedestal. Overall it was a great addition. The seat has much more support, and a higher back. The cons to me are the height without the bolster. I sit about 2" higher with the new seat, and more into the chilly air on the early morning runs. Good luck!
Dylan,
Do you have any pictures? I would love to make the same upgrade on our 1991 BF200, but also in the market for a new interior, so if I were to do it, I would want to do so before the new interior. Last edited by jeffbare; 01-12-2013 at 12:18 PM. |
Should be no pproblem. Most seat frames/rails are just screwed to the underside of the seat bottom.
Current: 2009 X-Star, Indmar 6L, 400hp, ZFT3 tower. Owned: 2012 X25 2011 X25 2009 Moomba LSV 2009 Moomba Outback V 2008 Monterey FS180 Pelican 4 set paddle boat plastic tug boat when I was 4 |
One thing to note I tried really hard to get the swivel functional, but our interior is too narrow for it to work. I would have to mount the seat offset of the steering wheel, and that just isn't an option for me. I can swing it about 45 degrees both ways, but that is the end of it. |
The good news is you probably have the same pedestal style I had, and it was an easy fix to drill some new holes. Make sure you fill the old ones in with some sort of sealant. |
