i have also had this issue, but it was from water getting to the starter, all was needed was the starter shaft to be greased and the fact that i had a loose battery wire sometimes did it this summer which is a pain in the a** in a 91 where you have to take the back seat out to access it.
#22
checked again
I have been putting off working on the starter. I was at the lake again this past weekend. I thought I would tinker with it. I noticed that when I was putting the screw driver across the terminals at the starter, I was not by passing the solenoid. when I did put the screw driver across the 2 terminals that bypassed the solenoid, the starter turned over every time. I guess this means it is the solenoid. Can I replace the solenoid without removing the starter? I attached a pic, but it is not very good. Hard to see which starter I have. My engine is a Mastercraft vortec engine.
thanks for any help |
#23
Pull the starter.
While you can do some service in place on most boats, you should be cleaning up the shaft, checking for play etc. I just had my starter completely rebuilt, with new bendix gear etc. for 110$ out the door. Worth the money. |
#24
Remember to apply a little grease to the shaft the starter drive rides on.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WEEKEND WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
#25
does it get worse when it warms up? I had an issue where I replace the battery cable terminal ends and solved starting issues. My ends didn't even look bad. Clipped old terminals, installed new ones, and then coated with corrosion resistant.
#26
Jibber,
I have the same solonoid that you have in the pic. How do I get it apart? I got it off the starter, but I can't figure out how to get it apart. thanks, Greg |
#27
starter solonoid
Here is a pic from the other end.
#28
Sorry Greg. I donīt figured out now because the boat stays in a winter hangar bit far away. But i think Hunterb has better technical understanding a few posts about. If you also have a 2012er with starting problems my dealer will give me more information about the solution. It is apparently a common problem for 2012. I will post when i get them.
#29
Greg -
That appears to be non-serviceable. Note that on the end of the case with the electrical connections, the metal part of the body is bent inwards to hold the piece with the electrical connections in-place. You could use a screwdriver to bend that lip back outwards (making a really ugly mess of it), pull it apart and replace bits and pieces, put it back together and use a punch to bend the lip back into place (no, really, I've never done anything like that in my life ), but the probability of success and reliability of the result aren't worth it. Besides, the solenoid is sealed to avoid having sparks ignite any gas vapors in your bilge, and doing this would break the seal. Can you say bad day at the lake? I knew you could...I think it's time to get a new one. It should be a readily available part. /frank
1998 Maristar 200VRS |
#30
Is anything connected to this corroded stud?
