#71
Good luck with that! When you're done, swing by my place and get mine cleaned up. I could use a third battery and my amps need a better mounting spot. Also, all the speakers need to be replaced...minus the subs. Shouldn't take more than an hour.
#72
20 minutes max. That inside wall worked great for amps. I actually put one starting battery in the "cooler" and mounted the others against the bow seat wall. Created a large pocket of room under the passenger seat.
#73
Both batteries are in starboard locker for me. 750 fat sacs are going in so I guess batts will go forward a touch, under the starboard side seats. I surf goofy so that works better for me anyway. I just don't know how to wire everything correctly so I don't blow it all up. I want the stereo separate.
#74
The beauty of being a licensed electrician
#75
Ok so got some final product pictures this weekend. Excuse the blackberry quality pictures. Here are some before:
#76
And after
#77
List of items completed for the year:
Flush pro installed in lieu of Stock Merc recirculator. (block drains plugged) New Mtx speakers inside New amps on board charger 3rd battery installed new fuel gauge and sender new depth finder new decals (sides and rear) new sub under drivers seat carpet power washed bow filler cut & installed platform redone speaker wiring run through tower and my favorite part is that on the first crank....... ![]() |
#78
wow, that interior looks amazing! enjoy your new boat
Thread Tools | |
Display Modes | |
