Old 01-03-2013, 11:36 PM
nanneyman nanneyman is offline
Boat: 2008 197 prostar TT
Sunstream float lift release problem
One side of my lift releases a few seconds before the other side causing the boat to come down at an angle. I've had the pressure checked coming out of the manifold and it is fine. When there is not a boat on the lift it works fine it just happens when there is weight on it.
This problem started when i had to replace a stripped fitting and had the threads retapped. The new fitting is a little bigger, but has the same size opening in it. I also had to remove the manifold from the motor and reattach it.
Any suggestions on how to fix are appreciated!
Old 01-05-2013, 12:24 PM
jeffbare's Avatar
jeffbare jeffbare is offline
Boat: Barefoot 200 Yamaha ProV 200
Did you bleed the lines when you put it back together?
Last edited by jeffbare; 01-05-2013 at 12:30 PM. Reason: tried to delete double post.
Old 01-05-2013, 12:27 PM
jeffbare's Avatar
Old 01-05-2013, 10:13 PM
No, I thought any air in the lines wood bleed out through the reservoir? How do I bleed them.
