OJ Legend 14x17 1 1/8" slot prop
I have a 14x17 that has a fresh re work done on it.
'91 and older 190's did not come with the HO engine set up. When I got my boat someone had removed the gt40 heads for some reason. I still don't know why. Well with a ~240hp power plant and a slot Tranny I decided to go from 18 pitch to 17 pitch. It helped. It brought up rpm and the boat seemed not to struggle as much. I had 2 OJ 3 blade props that were 14x17. One that I used prior to engine mods and the freshly rebuilt prop I'm describing here was my spare. I rebuilt my engine to 325hp. Now I have 4 props. The 14x17 is a great rebuilt prop that has no dings. I traded an exact prop that I was using on my boat before engine upgrade for a 4 blade at a local prop shop to run after engine mods. I ran that OJ 4 blade that I traded for until I finally decided to go CNC a year later. Then bought an acme CNC and OJ CNC 4 blades both higher end props. It is better for me to sell this prop vs re pitch it to an 18 or 19. I dont think a 240hp/slot will have enough grunt to turn a 19 pitch and the 18 pitch was a little much. I would not sell this prop to any owner with a 285hp or higher 190 w slot set up. They will turn it too fast. '91 and earlier with the lower HP engines the prop will work great. This prop is in no need of repair. It was pitched from 18 to 17 and was my spare. I have never mounted it since the re-pitch. It is a fresh rebuilt prop. It's easy to find $100 props that need repair ($80-$100 extra) so my price reflects a prop that needs nothing but a home under a Mastercraft. This prop is in perfect shape. It looks brand new. It was rebuild and never mounted. OJ Legend keyed propeller 14X17 1 1/8" shaft Brand new $420 I'll take $200 & you ship.
Rollin' Gangsta Style Quote:
Have any pics of it? We're looking for one for our '91 ps190. It's a stock 351/slot, so I believe it's 240hp.
Yes I can get pics taken this week.
I can assure you that it is that bright golden brass color and looks brand new. I can assure you that the sister prop that I traded was a mirror image of this prop. It worked very well on my '93 190 (same hull).
Alright, well it sounds like just the prop we need. I just gotta confirm it with the old man, and then I'll let ya know. I still would like to see a pic though.
I'll post up a pic tomorrow or Friday. The boat is in storage 30 min away.
Sounds good.
#7
Here are the pics
Ok the #1 stamped inbeteeen the 14 and 17 means that that was the better of the 2 props that I had. Like mentioned in previous posting I had 2 identical props. I ran the #2 stamped prop bc the lake level was low that year and cared less for that one. This one has never been mounted since rebuild and re pitch Back side The next 3 pics pay attention to the key way for the shaft key. You will notice I take a pic of every blade. Hopes this helps confirm the perfect shape this prop is in.
#8
Thanks, how much for shipping to 55011? That's fine if it takes a few extra days if you go cheap with parcel post.
#9
Since it is cold as balls in MN I assume you don't need it in 3 days. Going out of town fri-sun and will check as soon as I get back. If I'm lucky I may have time to run by a shipping office before I leave town. Either way ill let you know. I'll be TT from the road this weekend so comunication is still available.
#10
Lol, yeah. No rush.
