recent startup of "click" noise from dizzy 351W
It did not used to do this. I recently replaced the distributor cap, and I've fired it up twice since then (on the hose, I have not run it on the lake). The first time no clicking noise, sounded just like before I replaced it. The second time I have a click, sounds like once each engine revolution (guessing). It is coming from the distributor at least it sounds loudest in that location. I pulled the cap, thinking mechanical contact of some kind. No dice. Everything inside looks like it's supposed to, no hitting going on between rotor and cap. And why would there be, seeing as caps are the same? So I'm at a loss as to why it started making this clicking noise. Any ideas? Should I worry? I'm the worrying kind lol.
I've linked a vid. You can hear the clicking when I have the camera close to the engine. http://www.youtube.com/watch?v=fumfA...ature=youtu.be
1984 Stars and Stripes Powerslot White with blue stripes. |
If the rotor is not hitting the inside of the cap anywhere, maybe a loose wire on the cap and you're hearing the spark arcing? Hard to tell by your video.
Nice boat BTW ![]()
I was njskier on here. |
Well it'd be embarrassing to tell y'all what the exact cause was. But suffice to say it is not doing it anymore lol.
Mum's the word. Glad you found and fixed the problem.
1998 MariStar 200 VRS, LT1, PowerSlot |
Oh come on you have to tell. It could help one of us avoid doing the same thing at some point.
Fess up! |
Tell us!
JTR
1983 MasterCraft Stars and Stripes Cream/Red Metal Flake "Powerslot" "The misery that is now upon us is but the passing of GREED-the bitterness of men who fear the way of human progress. The hate of all men will pass, and dictators die and the power they took from the people will return to the people and so long as men die Liberty will never perish." -Charles Chaplin- |
#7
I'm leaning towards Jerseydave hitting the nail on the head.......
I'm with Jerseydave's first thought. Been there before myself.
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com SPECIAL PRICING CONTINUES Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. Spare tires too. |
#9
Yup, only worse. It was running on seven cylinders, through no fault of its own. I had disconnected a lead to spray penetrating oil on the manifold bolts, and then forgotten to reconnect it, and indeed forgotten that I disconnected it in the first place. It was number five, so being on the other side of the boat while I was starting the engine and working the throttle, I did not see it the first day. JerseyDave put me on the right track. I need fewer distractions in my life lol.
#10
