  #41
Old 12-19-2012, 08:12 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
Originally Posted by kbrighton View Post
Not really concerned with top speed at this point. I have yet to try footing, and when I do, it will be behind either a MC Barefoot 200 or another guy's 390+ HP Gekko. I am more interested in getting my boat into the weekly rotation in my club, and have it pull a guy we call "human anchor"
Watch out... Once you try it you'll be hooked!
Bailey
'02 X-9
Lake Blue Ridge
Old 12-20-2012, 08:20 AM
Rossterman's Avatar
Boat: 2001 prostar 205V
Snap a pic of the intake manifold where it bolts to the head and i'll be able to tell you if a HO or not. From what is shown in the picture it looks to be the HO but need closer view to confirm. As was said earlier in this thread, square port heads were used on hiperf versions of 454s vs. more common oval port engines. The square port heads have huge intake and exhaust valves/ ports with 2.19 intakes and 1.88 exhausts. LS6 454 in the 1970s chevelle was relatively underrated at 450hp at the crank (net not sae) with 11-1 compression ratio and square port heads so a lower compression version in the 425 hp range wouldnt be a stretch.
Carb looks like a 780 cfm model 3310 holley. Snap a pic down the throats and see if it has tabs on the fuel venturis which was done to address some air-fuel ratio imbalances cylinder to cylinder due to intake manifold runner lenght differences. They will be tabs cast into the atomizing ring to disrupt airflow.
Nice boat and clean engine- found yourself a gem!
Old 12-20-2012, 08:42 AM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
My post was in response to another comment.
If youre not going to be barefooting behind the boat, I assume you'll be slaloming primarily? In that case, the big block may not be the best choice, as it comes with a 300lb weight penalty.
Old 12-20-2012, 10:51 PM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Little known fact:
The sometimes-maligned Tristar came out as a barefoot model with the 454 as standard issue. The '89 brochure refers to a "high-performance" 454 but doesn't list hp. There was one advertised on Texas Mastercraft's site a while ago that stated 425 hp.
Old 01-02-2013, 05:21 AM
Snipe's Avatar
Snipe Snipe is offline
Boat: 1998 ProStar 190
Jerseydave,
If you want to see this boat go to http://www.boattrader.com/listing/19...-190-101834162
I looked at this boat before buying my 1998.
Old 01-02-2013, 06:09 AM
byronic's Avatar
byronic byronic is offline
Boat: 86 19' skier 351 PCM
Originally Posted by Snipe View Post
Jerseydave,
I looked at this boat before buying my 1998. Had to pass on this one.
I can see the boat but it won't pull up the listing. Do they do that if it's been sold?
Old 01-02-2013, 06:13 AM
Snipe's Avatar
I don't know. I click on the link and all there is to the listing does come up. I do know that when I bought my boat, they did remove the listing.
Old 01-02-2013, 08:49 AM
DooSPX's Avatar
DooSPX DooSPX is offline
Found yourself a pretty rare boat! Congrats! I have seen a lot of 91-94 Prostars, but never have actually seen a BBC 454 91.
A.K.A. One of a kind mistake
2011 Best In Show- 1987-2000 class
Trying to keep slalom alive
Need a new prop to fit your needs? Call Eric from OJ PROPS 800-359-9730
Old 01-02-2013, 09:24 AM
milkmania's Avatar
Boat: White/Red 91 PS 190
here's the webpage in PDF format
Old 01-02-2013, 08:13 PM
kbrighton's Avatar
kbrighton kbrighton is offline
Boat: 91 Prostar 190 - 454HO
I'm still scheduled to pick it up on the 13th. Pending a blizzard or other issues, I will be towing it home in 10 days
