Old 12-17-2012, 09:37 PM
kbrighton's Avatar
kbrighton kbrighton is offline
Boat: 91 Prostar 190
Originally Posted by wheelerd View Post
Found an old thread on 454 hp question:
http://www.mastercraft.com/teamtalk/...ad.php?t=31082
I have seen that thread. Good read. The engine also has a Holley double pumper carb installed, but I have no idea if that is a factory replacement piece or an upgrade. To me, coming from 17 years behind a Rinker 180 with the 3.0 I-4 Merc, this thing is going to drink a ton of gas.
Old 12-17-2012, 09:39 PM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
Very good condition indeed. 500 hours -- just barely broken in! That's an average of 25 hrs per year.
Old 12-17-2012, 09:43 PM
wheelerd's Avatar
Boat: 2005 X2
Once you get the boat and post a pic of the carb a dozen guys will ID it in a heartbeat.
More fuel than 3.0 Merc, yes . . . but a whole lot less than the massive engines in the new X's. Your boat is also so much lighter than the new beasts. That big block will hardly need to yawn!
Old 12-17-2012, 09:52 PM
wheelerd's Avatar
Boat: 2005 X2
454 fer sure. (AFAIK, Indmar never marinized the 427.) 375hp as I recall.
Nice find. Pics, pics, and more pics!
I dug out my old 91 TriStar manual. (Should have done that first!) Specs for the 454 are given as 390/425 hp.
Old 12-17-2012, 10:28 PM
EricB EricB is offline
Boat: 1983 Stars and Stripes Powerslot
That's a beautiful example of a 91 ProStar. It is in great shape and 500 hrs is nothing. Yes, it will use more gas than your Rinker. The faster you go...the thirstier it gets. So if you do alot of footin' you'll be at the pump alot.
Old 12-17-2012, 10:32 PM
One thing to consider is if the carb isn't original, it may not be a marine carb, and could be used in your favor if you haven't set a price already. A couple decent pics will get you the answer quickly enough.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 12-17-2012, 10:44 PM
kbrighton's Avatar
I posted the only engine picture I have. Don't think it could be ID from it. Just from talking to the owner, I would guess it is the correct carb. He has had it for 12 years, and had all the right work done. Replaced the exhaust manifolds recently as well.
Old 12-17-2012, 10:53 PM
Can't tell enough from that pic. Need to see the carb with the flame arrestor off. The only reason I brought that up is from your earlier post that said it has a double pumper carb, and marine applications don't normally use a double pumper carb. Again, I'm not a GM guy, so don't take my word as gospel.
Everything else looks great, even the fuel pump vent line running to the carb. I only bring up the non-original parts as my '77 came with non-marine starter and carb. As this was my first inboard, I didn't know the difference, but quickly learned the ropes from all the knowledgeable folks around here.
- Peter
TIRE & WHEEL SALES
Old 12-18-2012, 12:11 AM
SPSinclair 190 SPSinclair 190 is offline
Boat: MC Prostar 190 1993 351 PP RED AND WHITE
Brighton where in Iowa are you from ?
Old 12-18-2012, 12:35 AM
Covi's Avatar
Covi Covi is offline
Boat: 1986 Mastercraft, 19 Skier, PCM Ford 351
89 owners manual reveals the following about the Chevy 454
There were two 454's. Both were 7.4 litre. One was coined an HO. Here are some specs.
Both the same
Displ. 7.4 / 454 CID
Bore & Stroke 4.25 x 4.00
comp ratio 8.8:1
Block GM
Fuel Sys Holley 4 barrel
Not the same
RPM HO version turns 200 more per min. @ 4600
HO was a left hand rotation only.
Net weight of engines are identical.
