Old 09-11-2005, 06:19 PM
BigBarney's Avatar
BigBarney BigBarney is offline
Boat: '03 X-30, LQ9
Fuel sender unit
Anyone pulled their unit to test the fuel gauge reading. My gauge pushes past "F" when I crank the boat and a friend suggested that the float may be stuck since I winterized it for so long with a nearly full tank.
When I first got the boat out of storage and started her up, the gauge wouldn't register at all. Then after about 5 minutes of idling, it worked. Since then, it has goofed up. I just want to test the unit before buting a new one.
Is it as simple as unscrewing the unit from the top of the tank and moving the float around while looking at the gauge?
I wuv U, U wuv me - we're a MasterCraft famawee!
Old 09-11-2005, 06:25 PM
mlange mlange is offline
Boat: N/A
Yep. Just remove it, move it up and down, and watch your gaugue.
If you need to install a new sender, I wrote a how-to article that's available on both MBO and the other TMC.
It's a very easy job.
Mike
Old 09-11-2005, 07:53 PM
erkoehler's Avatar
Are you sure that you have a solid ground on the fuel gauge? Make sure, before you make any purchases as, my gauge was off and tightening the ground simplified the problem.
www.boathouseh2o.com
