Old 12-14-2012, 04:10 PM
gonofry gonofry is offline
Boat: Prostar 190, 1990, 351 ford
190 Prostar engine problem
I have a 1990 Prostar 190 and yesterday noticed that there was oil and fuel mixture on my dipstick. Is this a fuel pump problem? At slow speed there is a lot of dark smoke and it is hard to start.
Old 12-14-2012, 04:15 PM
There is something making your engine get too much fuel. Likely sources are blown power valve, stuck float or the secondary side of the carb is stuck open. I would start by carefully looking down the carb while it is running to see where the source of all the extra fuel is coming from.
Did your engine backfire through the carb recently? That could cause the power valve to fail.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 12-14-2012, 05:03 PM
petermegan's Avatar
Not at all familier with your engine, but is it running a mechanical pump on the side of the block?
Old 12-14-2012, 06:31 PM
That is a mechanical pump. If the pump fails, the diaphragm usually fails and there is fuel in the overflow tube which runs to the carb.........another possible source- just not as likely as a carb issue.
- Peter
TIRE & WHEEL SALES
Old 12-15-2012, 01:02 AM
petermegan's Avatar
Ok, Just thought if a diaphragm had failed it would have been a large source of fuel directly into the oil. Have fun.
Old 12-15-2012, 01:09 AM
In theory it could, but with the engine running so rich as to be blowing dark smoke at slow speeds, it points to a carb issue. having fun is what it is all about. Cheers.
- Peter
TIRE & WHEEL SALES
Old 12-15-2012, 09:14 AM
Jerseydave's Avatar
TT Hero
Power valves are know problems on holley carbs but they usually cause a bad "stumble" on acceleration. Sounds like you have a stuck/sunk float or high float level. With engine warmed up and at idle, look down into carb. If you see it dripping gas into the venturis then you need to rebuild or replace the carb.
I was njskier on here.
Old 12-15-2012, 09:22 AM
There is always the possibility that some debris is not allowing the secondary throttle blade to close. Had this happen to me on the first days of a weeks vacation a couple years back. Popped off the secondary bowl, cleaned it out, put it back together and was good for the rest of the week. I do like blue reusable gaskets.
- Peter
TIRE & WHEEL SALES
Old 12-18-2012, 11:59 AM
rjracin240's Avatar
rjracin240 rjracin240 is offline
Boat: Mastercraft ProStar 190 1988 351 Wheezer
Might be a wild guess.......if you rev the engine before shutting it down this will also in some instances cause fuel to get past rings and into oil sump
Old 01-28-2013, 04:33 AM
petermegan's Avatar
Gonofry how did you get on? solve your problem??
