I have always used teflon tape for that connection and I have never had a problem with leakage.....
Ted W Hook Em' Horns Last edited by broncotw; 12-11-2012 at 03:52 PM. |
#12
A comment on tape- the yellow stuff is double-thickness and considered to be fuel/propane safe. I would use that over the white stuff, which might degrade over time because of fuel exposure.
G |
#13
Teflon tape acts as a thread lubricant. It can lead to overtightening, which can damage either or both halves of the flare or deforming the threads
#14
Opsss missed gweaver's spot-on post.. |
#15
“You realize your odds of winning the lottery are the same as being mauled by a polar bear and a regular bear in the same day”….E-Trade Baby. |
#16
Flared fittings should seal on the flare, not the threads. Using tape to accomplish the seal comprimises the integrity of the seal and can lead to a leak developing later on with dire consequences. Lightly lubricating the threads is ok but if not sealing correctly, do a proper fix on the flare sealing areas and don't put your boat at risk!
#17
+2 on not using teflon tape on flared fittings.
I think I know where your leakage comes from. Your gas is most certainly leaking from the adapter fitting between the fuel line and the primary fuel bowl. You know the fitting which has the screen on one side? That's the one where the leak is coming from. If not seated properly on it's thin gasket, it may result in fuel seaping through. Let us know what it was. |
#18
Flare probably distorted if possibly over tightened. I would replace and make a new flared fitting get a new nut and have a fresh joint. Or get a flaring tool (cheap) and reshape the flare at minimum...IMHO.
I am really MCOCD and it doubles when fuel is involved...
Love my boat, hate my trailer. |
#20
Comments
Thanks for all the comments and suggestions. Does everyone have a screen in their fuel line at the adapter connection? My 91 does not.
