Old 12-11-2012, 10:07 AM
kjohnson's Avatar
kjohnson kjohnson is offline
Boat: 1991 Prostar 190
Fuel Line Question
I have a 91 PS 190 and had to disconect the metal fuel line where it connects to the carbureator. I have had a lot of trouble getting the connection tight enough so that no fuel leaks out. Does anyone know if anything like pipe tape or some type of waterproofing that is used around the threads where the line connnects to the carbureator?
Love my boat, hate my trailer.
Old 12-11-2012, 10:21 AM
MLA MLA is offline
Boat: pontoon
Metal fuel line connections on Carbs are typically a flare fitting, so the actual threads do not do any sealing. I would inspect both halves of the flares as well as the threads. If there is a nick or grove in the flare, or if its out of round, it will not seal. If the threads are not fully seating, they will get tight before the flare is tights. may need to replace those pieces.
Old 12-11-2012, 10:23 AM
milkmania's Avatar
Boat: White/Red 91 PS 190
spit ballin' here
http://www2.cougarpartscatalog.com/muc1014.html
OR
http://www.speedwaymotors.com/Fuel-L...nder,2718.html
http://toolmonger.com/2009/03/02/har...-flaring-tool/
Old 12-11-2012, 10:30 AM
broncotw's Avatar
broncotw broncotw is offline
Boat: 2010 MasterCraft Prostar 190 TT, Indmar MCX GM 350
Are you using teflon tape???
Ted W
Hook Em' Horns
Old 12-11-2012, 10:42 AM
While MLA is right in that a flared fitting shouldn't need any thread sealant, a wrap of teflon tape goes a long way to ensuring the fittings will thread together well and provide a leak-free connection. Inspecting the flare and fittings should be done every time a fuel line is removed.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
kjohnson's Avatar
Teflon Tape
It did not leak until I loosened it, so I don't think I damaged the line or flared end. Maybe I just need to take it to a boat mechanic.
I have not tried teflon tape. I tried that on a previous boat and it ended up partialling clogging the line.
Old 12-11-2012, 11:01 AM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
No tape on flared connections. Are you using the proper tools and tightening method?
PCM 351w, 350hp
Old 12-11-2012, 11:04 AM
When using teflon tape, you just want to use a enough tape to cover the male threads on the fitting and not have any excess to clog things up. Wrap it counter-clockwise with a very little overlap so threading the fittings together doesn't dislodge the tape. Be sure to use a 1" wrench to hold the carb fitting while you tighten the line fitting. If you don't use a wrench on the large carb fitting, you will not get the connection tight enough and end up with a leak.
- Peter
TIRE & WHEEL SALES
Old 12-11-2012, 12:36 PM
Why would you recommend using teflon tape for a flared fitting? The threads are not part of the seal.
PCM 351w, 350hp
Old 12-11-2012, 12:46 PM
Post #5....
- Peter
TIRE & WHEEL SALES
