Old 12-10-2012, 11:12 AM
SkiDog's Avatar
SkiDog SkiDog is offline
Boat: 92 Prostar
I'll echo the same sentiment. Cool idea, but for us anyway, hardly ever used.
If you do get one, make sure you run it periodically. Unless you want to see the nasty cr@p that comes out of it after the water has sat in the jet/hoses for a year!
Also install adequate access to the pump/plmbg. Nothing like having to tear apart your tub surround or cut a hole in the ceiling below to fix it.
Around here, it is part of the building code to have EASY access thru an access panel NEAR the motor.
It also helps to fill the tub with water just above the jets and put some bleach in it to get rid of all the crappy buildup in the lines. Do this about once a month at least!
Old 12-10-2012, 01:41 PM
JohnE's Avatar
JohnE JohnE is offline
Boat: A 2009 X14
I wouldn't put one in if you gave it to me. I'm doing 3 big showers in mine.
'97 Prostar 190 - LT-1
Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar.
Old 12-10-2012, 01:54 PM
JohnnyB's Avatar
JohnnyB JohnnyB is online now
Boat: 2004 Prostar 190
Originally Posted by Skyskiguy View Post
Forget the jacuzzi bath - if you want bubbles buy a hot tub. I'm a production home builder and I can tell you that we do very few jetted tubs anymore.
X2
Sent from my Motorola RAZR MAXX using Tapatalk 2
2004 Prostar 197, ACME 843
Old 12-10-2012, 02:04 PM
mattsn's Avatar
mattsn mattsn is offline
Look at the Ultra brand. I have had one for 5 years plus. No problems.
This tub does NOT circulate water thru the jets, instead, in brings in heated air from the room and sends in thru the many jets. This will circulate the water. The advantage is that you DO NOT HAVE WATER SITING IN THE PIPES AND JETS when you are finished. As a result no mold or nasty water.
Ultra is $$$$, but worth it.
