Old 12-16-2012, 12:36 PM
munkymush munkymush is offline
Boat: mastercraft x2 2004 mcx
310 predator exhaust gaskets
ive just removed the manifolds from a 2003 predator engine to find it hasnt got any gaskets between the head and manifold? a guy i know told me his indmar engine yrs ago never had any fitted either? is this correct or should there be some? thanks glenn
Old 12-16-2012, 12:45 PM
TOO-TALL's Avatar
TOO-TALL TOO-TALL is offline
Boat: Mastercraft X2 2003 mcx
My 2003 MCX was the same.
When I rebuilt the motor I put in gaskests and also used high temp silicone.
---Animal house
Old 12-16-2012, 01:39 PM
j.mccreight@hotmail.com j.mccreight@hotmail.com is offline
Gaskets are not needed when items are new, being smooth and true, when servicing these items gaskets are required, alot of mfgs do this, it cuts down on production costs.
James
Old 12-16-2012, 07:58 PM
i will get gaskest and fit them seeing as its 9years old now.. one other thing ,the thermostat on this engine was fitted in the bottom housing, ie where it would be in a car not in the top thermostat housing, im sure ive only ever seen the stat fitted under the top thermo housing cover? is this correct ?
Old 12-16-2012, 08:17 PM
Hmmm. Good question my ford has the thermostat on the upper part of the housing not on the intake manifold side, maybe somebody with a 310 predator can chime in.
James
Old 12-17-2012, 03:27 AM
ive always thought the reason for the extended housing with the top stat is to allow water to get through the manifolds while the stats closed?
Old 12-17-2012, 07:37 AM
MCOCD@13 out of 10
This is informative and answers your question on water circulation in marine engines.
http://www.boatinghowto.com/content/...tems-work-240/
