My valve cover thread
Ok guys so I've been saying for a month or so I was going to re finish my valve covers, I finally finished it this evening.
This is how they started Next step was to remove all the old paint or whatever it was, so off to a buddies blast cabinet, that didnt work very good at all. Maybe it was his cabinet or maybe it was the paint they use I don't know. So I grabbed some aircraft remover as per what he told me. (I had never used before) let me just say don't waste your time with a blast cabinet! Before I could finish the first application to the first cover this is what it looked like I brushed the remover on with a cheap paintbrush and when I went back to put on the 2nd coat most of the pain came off with the brush. Then I went and washed with water hose and this is what I got Valve cover 2 wasn't so easy. After doing Same steps as the first cover an forgetting remover was on over night, this is what I had So I took both to the wire wheel on a bench grinder, you can see in the top of the picture the result. After cleaning on the bench grinder I washed and dried and prepped with scotch brite red pad, and shot some black After a few days of drying inside the shop I started scraping with a razor blade then decided to go for it with 80 grit and a sanding block After sanding all the black off the ribs and letters I cleared Probably can't tell by the clear pic that it was kinda dull, as per a member here I read the label on the paint an and realized it needed baked Tapatalk
1990 prostar 190, 351, powerslot 1.5:1, tinted windows |
Looks Great!
MISS "B" HAVEN 2007 X2, Indmar 350 MCX OJ 13.7 x 15.5 2006 F150 SCrew Puller http://www.crowniehq.net http://banners.wunderground.com/weat.../OR/Albany.gif |
nice work! I too, did a rehab on a set of valve covers just wish that I would have clear coated the covers when I did it
1981 MasterCraft 19' Skier 351W PowerSlot Deluxe Long gone is the Trans AM
So after cleaning the oven 3 times and getting the smell out which turns out coulda been bad (d.a. Me didnt think about toxic fumes) I got em cooled and ready for install Sitting on my bow Installed some new valve cover gaskets And installed valve covers Tapatalk
I used part store vht brand paints, worked very well and I'm happy with it, sorry I didn't get it all In one post and it got spaced out.
Mods can you fix that?? Tapatalk
Nice work on the valve covers, you breathed new life into them.
Thanks for the compliments guys! I've got a ways to go on the engine still as you can probably tell
Tapatalk
Nice... the '95 350 rocker covers are so boring...
Deja Vu
I like the crinkle texture paint.
I wish MC still put these on their boats |
