#91
![]() Oftentimes the laborers get overlooked.... That's like tipping the tire guy a $20.00 because he gets your free tire rotation done ASAP ![]()
Jeff we had Grouser tracks for our bobcats and got dog-bones, bolts and bushings from LEPPO.
#93
Building code here states that the foundation can not be back filled until the first floor framing is installed. That never happens. Typically it doesn't even get braced. But the excavator needs to be careful. I know of 2 foundations in the past week that have been damaged and needed to be repaired due to carelessness.
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
#94
I highly recommend first floor framing before backfilling when using block. Its just not strong enough to hold it back with big spans. And I would have them fill the block with concrete and re-bar if its not required in your area. I am a GC in NC and that is the only way I will even consider block. Though we have a really heavy red clay in our area and creates a lot of pressure on the walls.
______________________________ You look like I need a beer! 2001 Prostar 195 |
#95
Never thought of talking to Leppo, thanks for the tip I will check with them today.
#96
My plan at this point is to have the slinger truck gravel 6' up the back wall while we dump in the side walls keeping pace, then put fabric over the top and grade the dirt level in accordingly. As always, suggestions and tips are appreciated. |
#97
Don't know how to advise w block. In a poured foundation we do 2 coats of waterproof coating. The drain tile has a fabric sock. We do 2 ft of gravel and then back fill.
I also put 2" of foam board on all exterior foundation walls and 1" and poly barrier under the floor. My basement is dry and warm. Had energy star model it and crunched several insulation options to get best bang for my buck! Sent from my Motorola RAZR MAXX using Tapatalk 2
Everyone Dies, but not everyone lives ![]() 2004 Prostar 197, ACME 843 |
#98
If you need fabric to lay over the footer drain, PS Construction fabrics (or something like that) in Rittman has or had the best prices. I have not been doing the underground stuff since '06. 57south to eastern rd (east), north on Pifer. usually it is 12 or 16' widths.
#99
12/8/12 Update: Basement is starting to look like a basement!
The progress continues and despite the rough start to the week and the wet weather, things have really taken shape.
They are calling for rain the next 3 days so I doubt anything new will take place until Tuesday or Wednesday but they are saying they will be done laying block by the end of next week.....weather permitting of course. Enjoy. |
#100
ya know...
you could make that mote all the way around the house and then....... ![]()
