Old 11-28-2012, 10:59 AM
Dino Don's Avatar
Dino Don Dino Don is offline
Boat: mastercraft 190 1987 351 Indmar
Striaght fitting verus elbow fitting?
My 87 190 w/351 eng has a striaght fitting for the hoses coming from the frt of the engine to each exhaust manifold. Anyone know if replacing that with a 90 degree elbow fitting, which would make running replacement hoses much simpler it would seem, if that would cause any issues as to flow to the manifolds etc.? Thanks for any thoughts----
Old 11-28-2012, 11:05 AM
There should be no problem as long as the elbow if formed so that it is not a restriction.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 11-28-2012, 11:11 AM
As long as the flow rate isn't extreme, using a rt angle shouldn't be a problem and if you can make smooth hose bends instead of rt angle, it won't kink. If you need, 45 degree fittings should be easy enough to find, too.
Old 11-28-2012, 06:38 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Do it. Many of the older engines came with a brass 90 deg fitting. I always convert over from the plastic / straight to the brass 90s if the engine needs it.
Old 11-28-2012, 08:55 PM
Dino Don's Avatar
Thanks think I'll look for 45's and then if not there use 90's.
