Old 11-22-2012, 11:09 PM
SWGA Boater's Avatar
Boat: 1991 Prostar 190
Starter needed for 77 S&S
Looking to find a reman starter for my "new" 1977 stars and stripes. Boat has a 351-rh rotation and is equipped with the Escort package. Not sure if that makes a difference??? Any links or part numbers would be helpful.
Also for question sake I see parts for PCM engines and such in Skidim but no Escort parts. Can these be interchanged? New to inboards so that may be a crazy question.
Thanks!
Old 11-23-2012, 12:17 AM
j.mccreight@hotmail.com j.mccreight@hotmail.com is offline
RH rotation? I would double check that, iirc it should be LH. As far as the 351w engine itself plenty of parts are interchangeable after all it's just a ford engine with the marinization items added later. Your on the right track with skidim they have a vast knowledge of inboards, although they can be a bit high on some parts.
James
Old 11-23-2012, 01:37 AM
DemolitionMan's Avatar
DemolitionMan DemolitionMan is offline
Boat: 2008 Pro Star 197 TT #58 of 100
http://www.skidim.com/prodinfo.asp?number=RK122014
Old 11-23-2012, 11:00 AM
Yes I don't know why I put rh but meant lh rotation. Thanks for the links. I am working up a Skidim order and will add the starter to my list.
Thanks!
Old 11-26-2012, 12:46 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
MC did put some RH engines in during the mid-late 70's, so I wouldnt necessarily dismiss the RH possibility based on what this forum thinks. Take a look at your engine/starter/prop and be sure!
RH would be reverse rotation and would require a CCW starter (LH = CW starter). If that is in fact what you need, they can be found new for <$150.
PCM 351w, 350hp
Old 11-27-2012, 11:23 AM
sam196370's Avatar
sam196370 sam196370 is offline
Boat: 1979 Stars & Stripes
I put an Arco starter in my '79 and would recommend it to anyone, a lot smaller but more powerful than original.
Old 11-27-2012, 11:24 AM
1redTA's Avatar
1redTA 1redTA is offline
Boat: 1981 MasterCraft Limited 351W slot
I am a fan of the Arco I put in my 81 as well
1981 MasterCraft
19' Skier 351W PowerSlot Deluxe
Long gone is the Trans AM
Old 11-27-2012, 02:47 PM
Arco makes both conventional and PMGR (permanent magnet gear reduction) starters. Theyre a brand, not a style.
PCM 351w, 350hp
Old 11-28-2012, 07:24 PM
Thanks for the heads up on the Arco starter. That is what I am leaning towards unless I can something similar. There was an older Ford starter in pieces in the boat when I bought it. Been searching the net with the part number on the cap, but haven't been able to come up with anything. May not have been a marine starter in the first place....
Old 11-29-2012, 10:57 AM
First you need to determine which rotation you need... but both conventional and PMGR starters are readily available for both rotations.
PCM 351w, 350hp
