LH turn. Found an Arco last on the web for 130.00 plus shipping. Seems like a good deal.
#12
If PMGR, thats a reasonable price.
How did you determine whether you had a RH vs. LH engine?
PCM 351w, 350hp |
#13
Looking at the prop on the boat now I determined it is a LH prop. Would this not be correct for the motor/starter also? New to inboards and do not want to order the wrong part.
#14
Prop rotation and engine rotation will be the same... the LH vs. RH naming convention for marine is not necessarily the same for automotive, so be careful how you specify. If youre confident that the prop on the boat is a LH and was correct, then a starter for a LH engine (CW) will be what you need.
PCM 351w, 350hp |
#15
TR,
Snapped a pic of the prop on the boat. I am correct with my LH rotation determination??? Want to make 100% sure before I order the starter. Double checked also that it was a PMGR starter. ![]() |
#16
#17
- Peter TIRE & WHEEL SALES email:tiresplease@gmail.com WEEKEND WHEEL SPECIAL Two 14" Aluminum wheels $195 Two 15" Aluminum wheels $215 Four 14" Aluminum wheels $370 Free Freight within lower 48 Steel and galvanized wheels available. |
