Draining block
Will leaving the cooling system full of lake water over the winter be harmful if you know you will not have freezing temps to deal with. 5 months the boat will sit. Thx
David 2008 X2 MCX ![]() 1999 Maristar 210 (sold) 1996 Bayliner 2050 |
Considering the little time and effort required to drain and winterize an engine (the basics), I can't see why you would want to take the chance. If it was mine, I would definitely drain and fog it.
The x2 is at a lake home garage connected to the house and boat is very difficult to maneuver and tower is down so it is not easy. I failed to put in my first post "I know,I know, I know it is better to drain it" but that wasn't my question.
Unless you can be absolutely sure it can't possibly freeze, under any circumstances, go ahead. You didn't post anything about the tower, garage, etc, so I based my answer on easier access but if you don't want a bad wake-up call in spring, I still recommend draining it.
Besides risk of freezing, I would think that water in the system would promote internal rusting of the engine....that's why I always drain mine and refill with -60 West marine anti-freeze. It has corrosion inhibitors in it according to the label.
JimN, curious on your thoughts about leaving block drained vs filling it with a/f?
I was njskier on here. |
Did some research on this this year and you could do a number of things if your concerned with corrosion. #1 - the moment water touches iron/steel it begins to rust. There's only so much oxygen dissolved in the water and after a certain period of time the rust reaction would stop. #2 - You could run some "Evaporust" thru your cooling jacket and let it sit overnight. It's non-corrosive and gasket safe to remove rust from your water jacket. It's pricey but it works. 5 gallons will cost you about $100. I like it because I believe it will keep the water passages clear. I also now wet store my block because of the corrosion inhibitors.
That being said - once you drop her back in the water the rust cycle starts all over again. I would to buy aluminum exhaust manifolds and risers - but the price so high. JimN - which year has an aluminum block and heads?
Thanks JimN...I hear ya on the tools in the garage...had to do the same thing...dang rust!
I was pretty PO'd when I saw it. The problem was that I needed to use it at the time and it took 3 hours to finish getting rid of the rust without screwing up the surface.
