  #61
Old 03-09-2013, 09:31 PM
Originally Posted by SWGA Boater View Post
Pulled a four hour grinding session this afternoon. Have I mentioned how I hate grinding? Have the transom ground smooth except in the lower corners where it is reallly tight. I plan on using a little barrel disc tomorrow afternoon to finish the transom up. Grinding is slow on the driver's side. I found several places with some rotten glass and blisters. These areas look to be over the bunk. I checked the bottom of the hull and cannot find any blisters. Not sure under the bunks. I hope the rotten glass and blisters are related to the previous floor replacement. Had to grind down to the gel in several small places. Will have to patch these prior to the stringers going in. I'll post some pictures when i get the boat vacuumed and washed out. US Composites order came in on Thursday, so i have to get myself in gear and get back on the boat.
I think I am going to try and replace the transom in one piece. I bought a ski eye that I plan to add to the transom. I am hoping to cut the transom to size, and then put some weight on it to start the bend. I then will use the ski eye holes and swim deck holes to pull the transom tight. That is the plan unless somebody else chimes in with suggestions.
Can't decide on glueing the transom in with PL glue or us thickened resin. Any thoughts?
I have been wondering how you are going to get this back together. I will continue to follow.
Old 03-09-2013, 09:40 PM
SWGA Boater's Avatar
Boat: Not a MasterCraft
I hope it works....3/4" ply doesn't like to bend....
Old 03-09-2013, 10:26 PM
Not much. Have you considered building a jig?
Old 10-16-2013, 03:47 PM
CCAnderson's Avatar
Bump-
How is the boat coming along?
Old 11-28-2013, 01:22 PM
phickman phickman is offline
Boat: 1973 MC Skier and 1970 MC Skier
I bought the project from Ansley. New stringers are in. Getting ready to install the engine. Transom and stringers are done.
Old 11-28-2013, 01:34 PM
Paul you know the rules - no pictures - didn't happen
