Old 11-19-2012, 10:14 PM
Juiced190's Avatar
Juiced190 Juiced190 is offline
Boat: MasterCraft, Prostar 190, 1996, 350
96 Prostar 190 fogging question
I recently purchased a 96 Prostar 190 with chevy/indmar 350 TBFI. After winterizing my 91 Prostar 190 with 351 for 4 seasons now, I plan to use the same procedure for the 96. My only question is, is it ok to pour marvel mystery oil directly into the throttle body fuel injection system like I do the Holley carb on my 91? This is obviously for fogging the cylinders.
Old 11-20-2012, 08:22 AM
MCOCD@13 out of 10
You can fog any wet intake in this manner. I have the '95 TBI and fog this way.
Old 11-20-2012, 09:52 AM
Juiced190's Avatar
Thanks Mike, how much Marvel do you use in your TBI? One other question, my owners manual recommends 20-50 racing oil. What oil do you use? Thx
Old 11-20-2012, 10:36 AM
MCOCD@13 out of 10
regarding marvel - I run a few ounces whiles its running till it almost dies...and then I shut it off. I use valvoline synthetic VR-1 plus 20w50 a bottle of Hy-Per Lube Zinc Replacement additive. I personally like the synthetic base oil stock because they stand up better to heat - just in case I suck something up my raw water intake and have an overheat situation. I add the Hy-per lube zinc replacement cuz of my MCOCD. It's a lubricant that was developed for C&C machines and has proven wear reduction properties. That plus the high zinc prosperous content of the VR-1 calms my OCD over having and older flat tappet engine.
Old 11-20-2012, 10:53 AM
Juiced190's Avatar
Mike, great info and very precise. What transmission fluid do you use? I have the Hurth 1:1. Thanks again!
Old 11-20-2012, 11:10 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Current incarnation of Dex/Merc will be fine. Listed volume is 1.75 quarts. However, you should measure how much fluid you remove and only add back that much.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 11-20-2012, 11:12 AM
MCOCD@13 out of 10
Hey Juiced - I used Castol Transmax Dexron VI. It's a dino/synth blend. going to go to a 100% synth next season like Mobil 1 ATF. +1 on the volume requirements from EastTX
Old 11-20-2012, 12:09 PM
Juiced190's Avatar
Thanks East and Mike. My owners manual says Dexron II, but I just wondered if anything had changed. Any recommendations on transmission fluid for 91 Prostar 190 with Velvet drive 1:1? It can be confusing keeping up with the latest recommendations. I really appreciated the knowledgable advice found here.
Old 11-20-2012, 12:42 PM
Dex/Merc on the 91 as well. I can't remember where I read it, but I seem to recall Synth being a no-no on the transmission fluid. Frankly, I don't bother with it in the engine oil department either. I run the VR-1 20W50 Dino and have for several years now.
FAQ
Tyler Ski Club
Old 11-20-2012, 01:37 PM
MCOCD@13 out of 10
I read the same on some transmissions that the synth is too slippery....but can't find the article anymore...Mobil 1 Synth is approved where Dexron IIIx applications are indicated. The same is listed for Royal Purple Max ATF. I personaly like prefer that synthetic base stocks for both crank case applications and transmission applications have better oxidation properties and heat/load properties. Just my personal preference....
Now I will have to go find that article EastTX...
prostar 190 winterize
