Old 11-19-2012, 04:17 PM
RickH RickH is offline
Boat: 2005 205 Prostar
Fuel gauge problems, 2005 Prostar 205
I have a strange one on my 05 Prostar 205. Fuel gauge stays on full until level gets very low then it moves all at once to just about the empty reading. I have changed the sending unit and also put in a new fuel gauge just to eliminate that question. The strange thing is I can unscrew the sending unit and hold it in a few up and down gas levels and it actually shows a reading on the fuel gauge but when I screw it back in place it goes back to full and stays there etc. Any suggestions would be greatly appreciated........
Rick
Old 11-19-2012, 05:13 PM
Ski-me's Avatar
Ski-me Ski-me is offline
Does it need a grounding wire by chance??
- Jeff
1994 205, LT1
Old 11-19-2012, 08:32 PM
Rossterman's Avatar
Boat: 2001 prostar 205V
Gas guage will read full until under 1/2'tank because sender is at the back of the tank and due to how the boat sits in the water, it takes quite awhile for the sender to read anything but full. When I first took out our boat, I thought the same as you- even took off the fuel guage wire to check and it moved from full to empty. Once I had the center floor up, I realized based on the gas tank shape why.
Old 11-20-2012, 12:31 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
I have an 05 X2. Same hull, same issue.
Old 11-20-2012, 08:14 AM
Thanks....the only issue on those replys is the gauge worked perfectly from 05 to this summer then during the first time out it stayed full until gas was almost empty then decided to work. When not in use the boat is on a level lift and the gauge still doesn't read any differently.
