Old 11-17-2012, 08:30 AM
Weathers5 Weathers5 is offline
Boat: 2003 Mastercraft 205V, Vortec MCX
Master cylinder for 2003 trailer
I have decided to go ahead and get a new master cylinder for my trailer. Do I have to go through a dealer to get the replacement? 2003 tandem axle trailer
Old 11-17-2012, 08:55 AM
Cloaked Cloaked is offline
Boat: MasterCraft
No. They are readily available and is an easy DIY project.
One of several suppliers ==> http://www.pacifictrailers.com/
Old 11-17-2012, 08:58 AM
JDC's Avatar
JDC JDC is offline
Boat: 2004 Prostar 209 - 350 MCX
You don't have to go to the dealer.
Try this page on etrailer.com. http://accessories.etrailer.com/sear...inder&x=47&y=3
Jeff
Old 11-17-2012, 10:11 AM
JRW160's Avatar
JRW160 JRW160 is offline
Boat: 2003 X2
Do you have the reliable actuator and brakes? I've been thinking about replacing my master cylinder as well as my brakes. Let me know how it goes. I probably won't do anything until january or february.
2003 X2
Old 11-17-2012, 11:24 AM
Greenster Greenster is offline
Boat: Mastercraft Maristar 1998 LT1
I just did mine. It was very easy. Some tips/tricks..
Pull the entire assembly out first. The current entire assembly will tell you what it is exactly. Mine said to "replace with 34039 only" which was the part number for an A-60 with drum brakes. Yours will probably be different.
I ordered the part from http://www.pacifictrailers.com/ for only $161 shipped.
While I was waiting for the part to come, I drained the entire systems brake fluid. Be careful not to get the brake fluid on anything with paint as it may remove it.
Old 11-18-2012, 01:58 AM
wheelerd's Avatar
wheelerd wheelerd is offline
Boat: 2005 X2
I replaced the actuator on my former trailer (the X5) this past summer. As above, I ordered from Pacific Trailers. Undoing and attaching the flexible hose at the back of the reverse solenoid can be a pain. I pulled the swivel bolt on the swing-away tongue and rotated the whole unit as I first loosened and then tightened the hose at the fitting. Also, use a couple of 1/2" wooden dowels cut to fit to hold the rollers and mechanism in place as you slide the actuator into the tonque. Then, once the actuator is in place, just push them out as you replace them with the metal pins and attach the circlips.
