Old 11-15-2012, 09:33 PM
abehrens's Avatar
abehrens abehrens is offline
Boat: 2004 X-9 MCX
Uh Oops
Anyone know where I can get a new throttle arm? I got a new shift knob and the old one didn't come off nicely. It's off an '04 X9. Dealer wants $140 for the arm. Ouch
Old 11-15-2012, 09:45 PM
MCOCD@13 out of 10
lookin' forward to a good reply...this one could be called tuition.. sorry... i'm not sure which Morse or Teleflex control 04's have. $169 at Jamestown marine.
Old 11-16-2012, 12:19 AM
jfw432 jfw432 is offline
Boat: other
An option for some bling... http://www.danamarineproducts.com/Gr...8-60984bb9fed3
I don't know much about their products but I looked at pylons at one point and remembered these.
Old 11-16-2012, 08:06 PM
jmorone jmorone is offline
Boat: Mastercraft, X2, 2011, Indmar 5.7L RTP
Is that the bolt (or threaded rod) connecting the shift knob to the shifter arm that sheared-off? If so can you back out the bolt in the shifter arm?
Old 11-18-2012, 01:00 AM
pram's Avatar
pram pram is offline
Boat: 1995 Mastercraft Prostar 205
Send a message via MSN to pram
drill it out and use an easy out?
I live in my own little world. But it's OK - They know me here
MONKEY FACE
Old 11-26-2012, 10:04 AM
abehrens's Avatar
Boat: 2004 X-9 MCX
It was all one piece from what I can tell.
Old 11-26-2012, 10:06 AM
willyt's Avatar
willyt willyt is offline
Boat: 2007 xstar
JB Weld
Old 11-27-2012, 08:05 AM
Boat: other
If you haven't fixed this yet, I have another option for you. You could drill a 1/4" or 5/16" hole in both the knob and the shaft, tap both for a bolt, cut the head off a 1.5"-2" bolt, then thread half the bolt into the knob, and finally screw the knob and other half of the bolt onto the shaft. Use loctite on both ends and it'll work for many years to come.
Old 11-27-2012, 10:12 AM
tph's Avatar
tph tph is offline
I thought about the same thing but I think he's got a new knob he wants to install. I guess you could try to bore and tap the handle with the same thread size as the new knob and use the same technique.
Old 12-10-2012, 11:54 PM
02-230vrs 02-230vrs is offline
Boat: Mastercraft, 230 VRS, 2002, 330HP.
broken control arm knob
I just had the exact same thing happen to me on my 03 Maristar 230. You need to find out which control box you have. I ended up buying it from the dealer as I didnt know. Yours looks very similar and maybe identical to mine. For under $200 I ended up getting the entire control box. If you dont want to replace the whole assembly, you can take the arm assembly from the new control box (it ships already separated from the control box) in the shipping box. Then put the new arm with your new knob, onto the existing control box on your boat. The hardware is included. The new unit makes it easy to see the set screw you need to remove to get the arm off the old control box. Good luck.
