Old 11-09-2012, 12:51 PM
DanP DanP is offline
Boat: 1981
Create a smaller engine box?
Hi all..
I have been mulling over the various forums and haven't been able to find a solution to my question. I have a 1981 MC and the motor box is starting to fall apart. I was wondering if it is possible to reduce the size of the box to something closer to what the 90's MC's have (which also have the same motor - the 351W). There is obviously less airflow (or rather air resistance) in a smaller box, but there doesn't seem to be any issue with that in the later model MC's. They have roughly the same airflow pattern as my boat.
Thoughts?
Suggestions?
Old 11-09-2012, 02:09 PM
gweaver gweaver is offline
Boat: 1988 Prostar 190
The only problem I see would be what you pointed out- a smaller volume of air for the engine to draw from, but you're right, the newer boats seem to do just fine.
I think you could probably make a form out of thin plywood or foam-core board and use that to help mold fiberglass. Or build a wood engine box and then cover that in fiberglass. It would certainly open up the possibilities to do some custom touches- cup holders or sunglass pocket or something.
If you do it, post pics!!
Good luck!
Greg
Old 11-09-2012, 02:21 PM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
Air flow due to box size is a non-issue. The carb draws in several hundred cubic feet of air per minute... it will need to pull air in from outside the box regardless of its size.
Was MC still making their motorboxes out of wood in the early 80's? If so, just rebuild it any size you want out of original materials. I wouldnt glass over it on either side- that will accelerate rot. If its glass, why not just repair it?
60mph Barefoot Boat (video)
Old 11-09-2012, 02:33 PM
Clearly there is a lot of extra space under the box that can be eliminated. My boat came with an engine box from a late start & stripes. This worked for me until I located a period correct engine box and sold the old box through the classifieds. Perhaps you can find a boat being parted out. Most any inboard box will work. I don't know what you hope to gain. There isn't a significant difference between the box my boat came with and the correct box I have now.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 11-11-2012, 07:19 PM
Boat: 1981
Thanks,guys, for the suggestions. Making one out of glass would be a nice winter project.
I think I found intake volume numbers at about 170cfm. Can anyone confirm I'm in the right ballpark?
Old 11-11-2012, 07:31 PM
That would be the average- at high RPM, it's quite a bit more.
Old 11-11-2012, 07:38 PM
Boat: 1981
How much more are we talking, Jim?
Old 11-11-2012, 09:10 PM
Sullivan's Avatar
Sullivan Sullivan is offline
Boat: 2011 WTT ProStar 197
I was thinking there are some air ducts that feed the engine. I was thinking they come from in vent in the nose of the boat. At least I know I had some air ducts that fed right into the airbox compartment in my 81 Ski Supreme and then the air vented out the back of the boat and even had a vent I think in the air box.
Old 11-11-2012, 10:39 PM
Boat: 1998 Maristar 200VRS
CFM should be easy to calculate. Let's assume a 350 Cubic inch engine, which means it sucks in about half that per revolution - so 175 Cu in per revolution. At a 5000 RPM redline, we're talking (5000 * 175) = 875000 cu in / min., or about (875000 / 1728) = 500 CFM. Actual air flow will be a bit less, as the engine doesn't fully fill the cylinders at high RPM.
Hence, the popularity of 500-600 CFM carburetors for our engines.
Old 11-12-2012, 09:43 AM
Boat: 1981
Thanks Frank. Very simple and concise explanation for what could have been a lot of bumbling in the dark. So, does that mean those little vents at the back of the box would be more of an intake vent rather than an outlet? Or would the vent system from the hood be able to easily handle that kind of airflow?
My google-ing tells me that 500cfm is a bit of a tight squeeze through two 3 inch tubes without some sort of pressurized system. Especially since the surface area at the intake in the hood is even smaller than the cross sectional area in the tubes.
Sorry if I have gone way off topic from my original post. Im just curious about the air flow direction and source now.
