  #51
Old 11-12-2012, 07:14 AM
Originally Posted by jwp1504 View Post
Hi Guys,
I have bought myself a 2000 x star and it doesnt have anywhere to hook a garden hose in to the motor, and research tells me that a fake-a-lake is the thing to use. So i went a bought one, hooked it up, turned the hose one, and started the engine.. But no water came out the exhaust..
Was i doing something wrong? Isn't water supposed to come out the exhaust??
I ran the boat for only 1-2 minutes but i know that is more than enough time to ruin an impeller!
That's the reason I don't like them. I used one a few times and had major problems keeping it where it needed to be. It's a lot easier to attach a hose with a shut-off to the raw water inlet and KNOW you have water going to the engine. Any hardware store should have what you need, although I don't know what's available in Australia.
Old 11-12-2012, 08:06 AM
MCOCD@13 out of 10
I wasn't a believer...even with Tim(can't_repeat)...so one day when I was bored I spent $10 bucks to make the below. Even at idle the hose was unable to keep up...it did not drain instantly...but now a true believer...it was cheap..easy and 2 bottles of Blue Moon at your favorite watering hole.
Old 11-12-2012, 08:18 AM
mybobtail mybobtail is offline
Boat: x14
A jet ski and a boat with a car engine are two completely different machines and a jet ski doesn't have a rubber impeller- it has a metal one.
If you crank it for two seconds, you aren't doing much to the impeller. If the impeller was destroyed, something else is going on- does the hour meter show 3 hours, or is that how much time YOU put on it? The factory doesn't do many dry starts- it would be absolutely irresponsible for them to do that and leave it to the dealer to handle this kind of abuse. Did you check the oil cooler, yet?
hi jimn
yeh the boat says 3.5 hours I had been out on it the Friday before last 2days after I picked it up from the dealer.
mmm you got me thinking about the oil cooler.when I got it home I connected it to the hose and had abit of trouble getting the water to flow through it was like the end was blocked .i started it then the water started to come out the back as normal.how do I check the oil cooler
Old 11-12-2012, 08:46 AM
Originally Posted by mybobtail View Post
hi jimn
You remove the hose from the side closest to the hull (from a water flow perspective) and look or feel around for debris. Weeds, sticks, plastic bags, etc can all get in there and if they do, it blocks water from coming through. I have a set of hemostats that I bought at Radio Shack that works great for clearing out the stuff I found. Shop around for a better price.
http://www.amainhobbies.com/product_...FYZaMgodkysA4w
Old 11-12-2012, 10:41 AM
MCOCD@13 out of 10
hemostats? price will probably go up - big demand most likely in Colorado coming up... - sorry for the thread jack
Old 11-12-2012, 10:42 AM
MCOCD@13 out of 10
hi jimn
Try backflushing as well by running water thru the other side.
Old 11-12-2012, 10:55 AM
Buy several- give them as gifts.
Old 11-12-2012, 01:10 PM
madcityskier's Avatar
Wink
'nuff said' - good point Jim...
Well, maybe not quite nuff.
Old 11-12-2012, 04:16 PM
jwp1504 jwp1504 is offline
Boat: Mastercraft, x star, 2000, 330
Take is easy, we aren't a third world country!! Haha.
Yeah after using the fake a lake once i don't thing it'll be getting a start ever again!
Old 11-12-2012, 04:23 PM
Even if you were in a third world country, JimN is from Wisconsin (I believe) so he could identify.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
SPECIAL PRICING CONTINUES
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
