Old 09-07-2005, 08:37 PM
2skinny MC
86 MC problem
The problem seems to be when I've ran the boat for a hour and then shut it off, it won't start. Most of the time I can place a screw driver between the concetions on the resister, and it will refire. Just replaced the resister, rotor, dis-cap, plugs, wires. Help?
Old 09-07-2005, 08:43 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Sorry can't help but you did came to the right place for infos !
Welcome to the board!
Another hoosier !
Keep skiing!!!
Old 09-07-2005, 09:04 PM
Hoosier Bob's Avatar
Hoosier Bob Hoosier Bob is offline
Boat: 1993 MASTERCRAFT PROSTAR 190 285HP 351 INDMAR
I had an old CC that had moisture in the distributer. After an hour it would begin to condensate on the cap and the boat would not restart. The condensation was visable inside the cap. After a quick wipedown the boat would restart and run for awhile more. I used compressed air to clear it out but as I remember it took a couple treatments.
BAREFOOTING: I knew it was gonna hurt when I felt my arse cheeks hit me in the back of my head!
!UOY NAHT RETSAF MA I TUB KNURD EB YAM I
Old 09-07-2005, 09:30 PM
BriEOD's Avatar
BriEOD BriEOD is offline
Get rid of that mess and get electronic ignition 99$ and 30 minutes to install.
Old 09-07-2005, 09:33 PM
2skinny MC
Thanks Bob, I'll check that the next time I'm out.
Old 09-07-2005, 09:37 PM
peason's Avatar
peason peason is offline
Boat: MC, 209, 2002, 310 HP
Ditto on the electronic ignition - call SkiDim and order one - and if your not sure of the install they will talk you through it.
Old 09-07-2005, 10:05 PM
2skinny MC
hate to sound like an idot, who is SkiDim and what is there # ?
Old 09-07-2005, 10:45 PM
Leroy
http://www.skidim.com/Great boat/ski support with people you can call and they know what they are talking about! Info on the site.
Old 09-08-2005, 11:08 AM
ktn_cmu ktn_cmu is offline
Send a message via Yahoo to ktn_cmu
If you're talking about putting a screw driver between the connections on the ballast resistor sounds to me like you need the jumper wire. The jumper wire hooks to the coil side of your ballast resistor and to the "I" terminal on your starter solenoid. The "I" terminal on your solenoid has full battery voltage only when the key is in the start position. So, if you have the jumper wire in place properly, you'll have full battery voltage at the coil side of your resistor when you have the key in the start position. Same as when you use the screw driver, but in the way the manufacturer meant for it to happen.
However, you should consider electronic ignition...its worth it. Though, you are still supposed to have the jumper wire with the electronic setup too.
Kyle
Old 09-08-2005, 11:24 AM
I drew Picture of the setup...but it seems to be too large...is there a way to reduce the size (in bytes, not pixels) so I can post it here?
