X-10...any one make the jump from 750's to the 1,100's?
I have an '03 X-10. Last year I ditched the stock hard tanks in favor of Fat Sac 750's and also added the bow sac to even things out. This made quite a noticable diference in the wake, but I'm finding myself looking for more again.
While I know I'll never get an X-Star wake out of this boat, upgrading the boat is out of the question for the next few years at least. I am, however, considering replacing the 750's in the back with 1,100's and ading another 800lb sac on top of the walk way to the bow. Curious if anybody has gone this far with an X-10, and if so what the reuslts were? Basically trying to figure out if the added expense (not just the bags, but another prop, burning yet more fuel, and additional wear and tear on the boat) is justified by a significantly improved wake over what I currently have with the 750's, and bow sac or if the wake isn't going to improve that much due to hull design limitations. Thanks - Jason |
HI Jason
man just wondering im upgrading my ballast from stock to the 2x750 and the 400 in the ski locker. i have the same boat as you. do you have any pics of the wake or what the bags look like in the locker. also had did the bow sack fit? did you upgrade your pumps? just curious not that many x-10 owners on here. thanks!
2001 MC X-10 |
I don't have any pics of the bags in the boat, but can tell you the 750 fits perfect on the port side. I used a different 720lb bag on the starboard side as the boot/rinse down tank and sprayer eats up some of the room. I wouldn't go wider than a 20 inch bag without bracing the engine dividers/barriers. If I do the 1100s I'll need to brace the walls quite a bit and won't be able to fill them all the way as the lockers are 22 inches tall.
Im using the original pumps but plan on installing dedicated intakes for each pump to speed up filling. Front bag fits about perfect but really need another 2-300 lbs up front to get it on plane quicker. You will need a more aggressive prop. I put on a 1479 and it works great. Wake is considerably taller and steeper than with original tanks but I'd still like to see more out of it. Haven't been behind enough boats to give you a fair comp. All I can tell you is we can get about 5-6th of air with enough time to pull off back rolls and 360s. Just started hitting double ups which got me craving to get the wake cranked up as much as possible. If I go the 1100 route I may have my rear bags up for grabs if you are interested. Jason |
I bought mine this summer but work was crazy this year so I haven't been able to do the project. I don't have the sprayer on mine I'm an 01. Keep me posted on yours I'm interested in seeing what you end up with.
Thanks again for the info though
2001 MC X-10 |
