Ipod/Iphone Docking plug to amp
I would like to hook various Ipods and Iphones from their docking port directly to my amp (No head unit) and be able to use the Ipod/phone controls for everything, including volume. I would also like to have the unit charge while it is plugged in. Does such a cable exist? If not, what is the next best set-up?
Thanks. |
Yes, as long as you have only one amp.
You can get an Ipod docking cable (got mine form Car Toys) that has RCA jacks that you could hook into the amp's inputs (typicially hooks into the other source inputs on teh head unit) and it has a 12V +/- wires that you hook up to a 12V source for charging. If you got more than one amp you'd need to have an EQ or somethin between the Ipod and the amps or if you amps have pass thru inputs you may be able to hook to one amp and use RCA cables to transfer signal formt he pass thru jacks to the other amp(s). May be low on signal voltage if you tried to "split" the Ipod output signal to several amps though, not sure.
'06 X2 MCX "I understand why some people may not want to do this the way I have recommended but I can't understand the death grip some people have on a toilet plunger with a hose fitting." -JimN |
Look at the Fusion Electronics MS-IP600. http://www.fusionelectronics.com/mar...eries/MS-IP600 West Marine sells them and will meet online prices. |
I almost bought a Sony unit that had a sealed internal bay for iPod/iPhone, but too many bad user reviews where folks had problems with the iPod/iPhone overheating in the bay and shutting down.
Sent from my iPad Mini using Tapatalk HD |
The unit works awesome. Charges ipod or phone and allows you to view everything on the ipod, including playlists. http://www.jamestowndistributors.com...+Marine+Stereo
Jack ----------------------------------------- 1989 ProStar 190 Power Slot Somewhere between SML and LKG |
#7
The IP600 and IP700 are compatible with both, too.
#9
That makes sense. I thought it should be, but the web page only showed Ipod compatibility.
