Old 09-07-2005, 05:03 PM
BradD's Avatar
BradD BradD is offline
Boat: MC Prosport 1992, 351 Windsor
Send a message via AIM to BradD
Side Panel attachments
The side panels in my boat were coming apart. I'm not sure if I'm using the proper term. Basically the removable structures that provide the side storage for such things a stern light, paddles, etc... that run the length from the back bench up under the dash.
I quickly stapled them in place, but I want to do a more complete job on them.
I have found the 2 attachment bosses (Bolts) at the rear of the panel, but I want to know how many more mounting bosses there are. I don't want to start persuading the panel only to find out one is still attached.
1992 205 ProSport
Connelly F1
Old 09-14-2005, 06:59 PM
Hunterb Hunterb is offline
Boat: 1990 Prostar 190 351
Not sure if this helps or not, but I just rebuilt mine (PS 190). There were five original holes (I think) for the fasteners to hold each panel on. I built new panels and installed t-nuts in them prior to doing the upholstery. I'm not sure how the factory panels are attached as they were long gone when I bought the boat. All I'm going by is the holes that were there. T-nuts work great for holding them in place if you need to build new ones. You should be able to find the fasteners fairly easily by runnning your hand along the upperside of the inside of the panel.
Hope that helps.
Bruce
Old 10-19-2005, 02:36 AM
rem_pss308's Avatar
rem_pss308 rem_pss308 is offline
Boat: 1999 X-Star 330 HP
Send a message via Yahoo to rem_pss308
I took mine loose last year, the vinyl was coming loose from the board. Above is correct about 5-7 Attachments. Mine had 1/4" nuts . the studs were theaded on both ends and one end screwed into the boards. Hope this helps.
"Let me not pray to be sheltered from dangers, but to be fearless when facing them."
1999 X-star, 330 LTR, Zero FLex tower.
Old 10-19-2005, 02:38 AM
erkoehler's Avatar
When you get them all loose, the side panel will come right off with NO muscle needed. If you a pulling, twisting, or cussing at it then it is still attached.
Mine came off in about 5 minutes when I was doing my stereo install over the summer.
www.boathouseh2o.com
Old 10-19-2005, 06:31 PM
88 PS190 88 PS190 is offline
WEAR GLOVES! Fiberglass splinters... very nasty things. When we got our boat those had vibrated loose, and i got quite a few nasty little buggers in my arm, and to pick them all out and iodine my arm, it was not fun.
Old 10-21-2005, 12:49 AM
milkmania's Avatar
Boat: White/Red 91 PS 190
I've taken mine out and repaired them.....
but I gotta ask, why did they build them with 1/4 inch plywood???
If I ever build mine, it'll be much thicker material
Old 10-21-2005, 12:52 AM
erkoehler's Avatar
I'll second that, they are very flimsy, but I guess you gotta keep the weight down for a good wake!
Old 10-21-2005, 10:48 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
Erk, I'd suspect you're right. Probably weight.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 10-21-2005, 03:22 PM
scott88prostar's Avatar
scott88prostar scott88prostar is offline
Boat: 1988 Prostar 454 w/powerslot
If you use anything over 1/4 it might look bulkly after adding the felt and vinyl....Im redoing mine and Im using stainless steel bolts attached to thumb srcews so I can tighten or remove them...those inserts get loose over time....3m makes a really heavy duty velco which might work but you need to staple the velco to the wood so it stays...the glue attaches to the fiberglass really well....I was wondering if there is a plastic sheet that would never rot.
Old 10-21-2005, 03:24 PM
erkoehler's Avatar
I hope to never have to mess with mine again, and I'll leave it at that.
