Old 04-13-2014, 04:03 AM
flya750
Guest
Posts: n/a
Trailer jack for prostar 190 trailer - '97
I need to replace my trailers jack,
I've looked at the Fulton jack's but their mounting brackets doesn't match up with my 17 year old Mastercraft trailer.
Any suggestions as to a replacement jack for the older Prostar 190 trailers?
I've read in other threads to check out Shelby?
Thanks
Old 04-13-2014, 09:34 AM
Patrick Hardy's Avatar
Patrick Hardy Patrick Hardy is offline
Boat: 1996 Prostar 190 W/ LT-1 & Powerslot
I had mine replaced on my 1996 Prostar 190 last year. My local shop had to special order it from Attwood. It took two weeks to arrive and cost $110.00, but it was the exact model as the one I replaced. Just unbolt the old jack and bolt the new one in place. Real easy and OEM.
Old 04-13-2014, 11:33 AM
bturner2's Avatar
bturner2 bturner2 is online now
We have bolt on adapter plates for your trailer if you want to go with the F2. Make sure you measure your bolt pattern so you get the right one the first time......
http://liquidcut.com/
Old 04-13-2014, 12:50 PM
Boat: 1998 Maristar 200VRS
This.
I cheated and made my own (doesn't look nearly as purty as theirs does, however). But a 1/4" aluminum plate cut to size with 8 holes in it is the best way to adapt the old to the new bolt spacings.
/frank
flya750
Guest
Posts: n/a
I saw the ATTWOOD options last night while searching for Fulton alternatives....Thanks for the confirmation.
Old 04-14-2014, 01:23 PM
Guest
it wont match up... order the F2, its nice... take the trailer to a local welder,and pay them $40 bucks to grind off the old bracket and weld on the new one - it's worth it.
